Old 06-25-2019, 05:48 PM
not a charger not a charger is offline
Default 160 MPH speedo - GM, or repop - which is it?
When I purchased my 78 TA, the owner gave me this 160mph speedo in case I wanted to install it. I know these are available reproduction. The part # 6492882 W is on the back, and I know that coincides with the reproductions. However, there's also a stamp that says Feb2 1971. It this a genuine GM part? Odomert reads 63,394.0, which leads me to believe that it could be. Thank you for any help you can provide.
ID:	514819   Click image for larger version
Old 06-25-2019, 06:08 PM
Transamric's Avatar
Looks like the genuine GM item to me.
Old 06-25-2019, 10:47 PM
Aus78Formula Aus78Formula is offline
The repros are so good they even add date codes and miles
Old 06-28-2019, 01:27 PM
unruhjonny's Avatar
that's an original speedo all right.
That speedometer is from a 1971 model year car to be precise.
The speedo to swap in your 78 TA is the 1972.5-1974 speedo - not the 1970-1972.5 speedo;
Midway through the 1972 model year the seat belt warning system was added - this changed the speedo face - where it used to only have a (parking) brake warning at the bottom of the speedo, it now had both a (parking) brake & seat belt lights.
Here is a (faded) 1975-1978 speedo:
Here is a 1972.5-1974 speedo:
(these are not exactly the best pictures, but I tried to find two similar sized images which showed the speedo face with the brake & seat belt warning light spots.)
I hope this helps!
1970 Formula 400
