Old 09-18-2021, 07:51 AM
Jeff Hamlin's Avatar
Question 1963 1BC REPLACEMENT CARB NEEDED.
While helping out my late friends family sort his cars/project I decided to see what was going on with the 1963 Tempest with the 195 1BC since it really hasn't seen the road since our last outing in 2019 to the 18th annual Lonestar Round-Up a trip/memory that I will forever cherish.
Anyhow, I was able to get her to fire up in short order. After checking all the fluids. I backed it in and out of the garage. It was idling near perfect with excellent oil pressure. However once up to temp, it started running rough.
I quickly took a look under the hood and the carb was spewing fuel at the base.
I shut it down for a closer look and it appears to be coming from the throttle shaft, I could smell the foul fuel and decided to add a stabilizer to the tank as well as a small amount of fresh fuel that was on hand. I started it again and she idled perfectly with no leaks. Then sprayed carb cleaner into the carb while maintaining idle and all seemed to be holding.
I again put it in drive and in short order, it started leaking fuel under load.
So I explained to the kids not to drive it until the carb can be addressed.
This brings me to my question, are there any suitable replacements that you might recommend to use so the car could be made drivable so the OE carb can be hopefully rebuilt when time allows. His daughter wants to keep this Tempest and I want to help her all I can.
Sorry for the long post but really appreciate any input.
Jeff
Name:	ROUND UP SAT-22.jpg
ID:	573300   Click image for larger version
Name:	ROUND UP SAT-6C.jpg
ID:	573301   Click image for larger version
Name:	READY SET....jpg
ID:	573302   Click image for larger version
Name:	CITY LIGHTS 1.jpg
ID:	573303   Click image for larger version
Name:	GOOD NIGHT AUSTIN.jpg
Old 09-18-2021, 01:09 PM
padgett's Avatar
padgett padgett is offline
Lots era 6 cyl engines used a 1GC "Monojet".
Web Site
Old 09-18-2021, 03:34 PM
Drag Star Le Mans's Avatar
I agree with Padgett, put a monojet on it. My 62 LeMans didn't run so good when I bought it. I put a monojet from another car and it ran perfect, it's had a monojet on ever since. Sorry I don't have any laying around but any older auto wrecker should have some?
DragStarLeMans
Old 09-18-2021, 03:59 PM
padgett's Avatar
How about one of each ?
Web Site
Old 09-19-2021, 04:02 PM
TransaxleTempest62 TransaxleTempest62 is offline
Automatic or manual choke?
Old 09-22-2021, 06:42 AM
Thanks, guys, I think I found some avail, and looks like it may take some time to secure.
Hope to check into it this weekend.
Op #1;
https://www.oreillyauto.com/detail/c...rburetor&pos=0
Op #2;
https://www.autozone.com/fuel-delive...453/170107_0_0
Really hope we can get this Ol Tempest back out so the kids can enjoy it.
Tony and I always had a blast with this little 4 banger!
ID:	573573   Click image for larger version
ID:	573574   Click image for larger version
ID:	573575   Click image for larger version
ID:	573577   Click image for larger version
