Old 04-18-2014, 05:27 PM
WINGNUT WINGNUT is offline
Default What engine oil does everyone use for ZDDP?
I am concerned about the lack of ZDDP (zinc) in the newer motor oils. I have heard that a lack of ZDDP can potentially cause damage in engines designed to run with it. I have learned that some people are running diesel oil in older cars because there is still ZDDP in these oils. Is anybody here doing this? And if so, what brand and viscosity is recommended?
My '72 GTO has an unmodified 400 engine, and I think the oil spec is SAE30.
______________________________________________
1972 Pontiac GTO 400ci TH-400 (restoration project)
I know what I like, and I like what I know!
Old 04-18-2014, 05:38 PM
GRX's Avatar
GRX GRX is offline
I have had good luck using the Lucas zinc-plus additive.
1969 GTO hard top ~ Std bore 400, '70-RA3 block, 670 heads, Bal. & Blue... M22, 12-bolt w/3:55s
Old 04-18-2014, 05:44 PM
The Champ's Avatar
I run 10w40 Brad Penn in the GTO and 0w40 Mobil 1 in the Camaro. Both have enough ZDDP in the oil so no additives are needed. Mobil 1 15w50 also has plenty of ZDDP - I just didn't want to run that heavy an oil in the GTO as I do occasionally drive the car in colder temps.
Old 04-18-2014, 05:45 PM
geeteeohguy's Avatar
I've been running diesel-spec Rotella in my '67 (stock engine) for the past 10 years or so without issue. I understand even the diesel spec stuff is getting rid of the ZDDP, though. I also add a bottle of MOA additive from BG. The stock spec oil is 10w30 for these engines, which I recommend. The Rotella is typically 15w-40, which is a bit thick, but out where I am, it's very hot most of the time, so I'm ok with it. The main thing to avoid is racing oil of any kind, as it lacks the additives necessary to protect your engine under daily driving conditions.
Jeff
Old 04-18-2014, 06:19 PM
73T/A 73T/A is offline
Valvoline Racing VR-1 oil.And a dose of ZDDPlus for good measure.
2001 Trans Am,WS6 Sunset Orange Metallic (sold)
1973 Trans Am 455,4speed
1970 GTO
Old 04-18-2014, 06:24 PM
tekheavy's Avatar
tekheavy tekheavy is offline
Straight Valvoline VR-1 Racing Oil.
Old 04-18-2014, 06:58 PM
mchell's Avatar
mchell mchell is offline
VR-1 as well
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Old 04-18-2014, 07:00 PM
72projectbird's Avatar
I was about to ask the same question.
Right now Im running off the shelf oil with a zddp additive, but Im looking for an oil that doesn't need an additive.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 04-18-2014, 07:22 PM
propuckstopper propuckstopper is offline
Default Engine Oil
Amsoil Z-Rod in 10W-30.
Joe Gibbs and Brad Penn have similar offerings.
Old 04-18-2014, 07:31 PM
moneypit's Avatar
moneypit moneypit is offline
10w30 VR-1
37 Pontiac Sedan 455 700r4
94 Firehawk Supercharged 5.7 LT1 6spd.
77 Grand Prix base model, 350 pontiac
97 F250 7.3 turbo diesel
85 CJ7 Laredo
65 Impala SS 396, 4 spd, A/C.
Old 04-18-2014, 07:37 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is online now
Default oil
Brad Penn 10W40 and a Baldwin B9 filter.
great gauge response and good hot pressure.
Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, DUI HEI and Ram Air pans and RARE Long Branch Manifolds
Old 04-18-2014, 07:58 PM
ANDYA ANDYA is offline
Brad Penn for me also. Be sure and get the bottles that say Grade 1 on them.
Old 04-18-2014, 08:06 PM
1969GTO's Avatar
1969GTO 1969GTO is offline
BRADS PENN
color me gone
Old 04-18-2014, 08:09 PM
Paul Westcott's Avatar
Paul Westcott Paul Westcott is offline
Delo 15W40 with 1 bottle of ZDDP.
The 1967 Rustbelt Refugee. Work in progress. Donations accepted.
- 467 Cubic Inch EFI Pontiac, Megasquirt II v.3.O ECU, 700R4, 3.55 gears -
Best 1/4-mile ET: 12.79 @ 107.36 MPH - Best Fuel Economy: 18.47 MPG
...That's no GTO, that's a Tempest!
Old 04-18-2014, 09:44 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
Delo 15W40 and nothing else since 2001-2002 or so. No problems and tens of thousands of miles on many engines.
Old 04-18-2014, 09:48 PM
abefromen's Avatar
abefromen abefromen is offline
any conventional 10-40 and a bottle of ZDDP.
Old 04-18-2014, 09:56 PM
4dblnkldude's Avatar
4dblnkldude 4dblnkldude is online now
Brad Penn and a bottle of ZDDP.
Old 04-18-2014, 10:02 PM
pfilean's Avatar
pfilean pfilean is offline
Did use Mobil1 with a bottle of additive. Now I use Mobil1 for high mileage engines which Mobils website shows has more ZDDP than regular Mobil1.
Old 04-18-2014, 10:16 PM
Default brad penn
agreed with andy must say grade 1
Old 04-19-2014, 12:22 AM
Pontirag Pontirag is offline
there is an additive product approved by Continental. Lycoming and the FAA for use in aircraft engines. its runs about 8-11 bucks for a bottle. it has all the good stuff in it. those engines cost beteen 20-60 thousand dollars each so its not snake oil. Aircaft spruce sells it.
dont use too much of any additive or it will cause corrosion of some brass and parts. Many who build antique motorcycles learned this the hard way
