Old 12-15-2021, 03:00 PM
yolams yolams is offline
Default tri power carb rebuild
my 60 Bonneville has (3) Rochester 2 jet carbs that need rebuilding. I can not find any carb ID (missing tags and no stamping found). Does anyone know how to ID in order to buy correct rebuild kit?
Old 12-15-2021, 07:00 PM
carbking's Avatar
carbking carbking is online now
This may help:
https://www.thecarburetorshop.com/Tripowerspecs.htm
Jon
Old 12-16-2021, 08:47 AM
That is helpful - thanks!
The car is new to me and therefore I can not assume factory casting numbers would necessarily be correct. Is there a way to confirm the carb model from other physical characteristics (shape, size, bolt locations, etc)? Or should I buy multiple rebuild kits and simply try to match parts?
Old 12-16-2021, 09:27 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
If you have the correct float bowl numbers, order the 1960 rebuild kits from :
Dick Boneske - 920 450 1040
0r
pontiactripower.com (John Wright) or Call Mike Wasson 309- 360- 6385
Old 12-17-2021, 10:14 PM
Dick Boneske's Avatar
PM me, and I can send you the kits. Two ends and one center.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 12-18-2021, 08:52 AM
OK, thanks for the comments everyone!
Old 12-19-2021, 03:37 PM
The casting numbers for the float bowls are located behind the accelerator pump rod, just below the airhorn. The 1960 end carbs will be 7011997. Center carb will be 7019927 or 7019929. PM me and I will give you the prices of the kits. I can ship them this next week.
Name:	Tom Francis Carb 005.jpg
BONESTOCK GOATS
Old 12-21-2021, 01:20 PM
On many 7011997 end carbs, used from 1959 through 1963, the float bowl casting numbers are on the bottom, not the location I described in my last post. Sorry if that caused any confusion.
BONESTOCK GOATS
