Tri-Power Tech 57-66 Tri-Power Talk
Old 04-12-2012, 07:16 PM
wrea3_98 wrea3_98 is offline
Question RE
Yeah the manual is not specific to engine setup (ie, 4BBL, tri-power). Still scratching my head.
Old 04-12-2012, 07:25 PM
6T5 Cat's Avatar
6T5 Cat 6T5 Cat is offline
I've run Pontiac tri-powers on the street and strip since 1964 with my fuel pressure regulated at 6.5 psi and never had a problem. It has been my experience that over 7 psi you can run into issues lifting the needle off of the seat. Follow the information in the service manual, its written by the engineers who designed and built the carb. If you found evidence of bead blasting in the carb, then it was improperly rebuilt. Bead blasting the internal areas of a carb is a no-no.
[SIGPIC][/SIGPIC
Old 04-13-2012, 08:52 AM
Default RE
I have it up and running and Im only running the center carb to break in the engine. I have the regulator set at 3 PSI.
