Power window switch connector
Hi everyone. I've a 1975 GrandVille Convertible. The right rear power window switch harness has been cut and the connector has been lost to time. It is the flat, square, three wire connection that snaps on to the switch. Is this connector available? Thanks for your time. SL
Hi
I may have one..... Give me a day or 3.....
if I have a beater harness I will cut one off ... might put an ad under Grand prix 69 up should be the same the parts are Not here they are 45 minutes away ........ Many cars used the same one... 6" of wires do you ok ? Scott |
Yes. Thank you very much. SL.
