Old 09-19-2022, 02:50 PM
Speargun's Avatar
Speargun Speargun is offline
Default Speedmaster Heads Heater Nipple
I'm installing a set of Speedmaster heads on my new build and was wondering what everyone is using for the heater nipple? The heads are threaded with what looks like 3/4" NPT, but I haven't found a direct fit part.
I'm thinking 3/4" NPT to smaller NPT reducer bushing and then just use an NPT to nipple, or AN, fitting...
No!
Do not try!
Do! Or do not.
There is no try. - Yoda
1967 Firebird Restoration 2005 - 1/25/2017
Old 09-19-2022, 03:23 PM
Your thinking is correct.
Old 11-22-2022, 08:08 PM
74Grandville 74Grandville is offline
This is what I used.
EDGE INDUSTRIAL 5/8" Hose ID to 3/4" Male NPT MNPT Straight Brass Fitting Fuel
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I also installed a spacer i picked up from home depot to put inside the heater hose to block some of the flow like stock. I used a Hose clamp to keep it in place.
Hillman 1/4-in I.D. x 5/8-in O.D. x 3/8-in Long Natural Nylon Spacers
1979 Firebird Trans Am 301/4spd (Now 428)
1977 Firebird Formula 400/Auto
2007 Grand Prix GXP 5.3L
Old 12-09-2022, 09:16 PM
lust4speed's Avatar
The Edge piece looks exactly what Edelbrock includes with their heads. Think it would be a good idea as Grandville said to reduce diameter to a 1/4" somewhere along the way as Pontiac did with their stock heater nipples. Reduced flow in and full flow out of the heater core should help reduce internal pressure spikes.
Mick Batson
