Tri-Power Tech 57-66 Tri-Power Talk
Old 09-30-2022, 10:20 PM
Mwieczorek Mwieczorek is offline
Default Bought a tripower... Please help me figure out what I have here
I bought this tripower setup. (See pictures below) It's definitely a 1966 intake manifold. I'm not sure what the carbs are because the tags are all missing. Does anyone know if there is anything I can measure to determine what CFM the carbs are and if they are correct?
The center carb was opened up and I think some parts inside are missing. The needle and seat, float, accelerator pump plunger and such are there, but I think the accelerator pump discharge nozzles are gone. I ordered an inexpensive used Rochester barrel (that should be for a mid 60's Pontiac) to dissect and scavenge for parts. I know I'm missing the choke pull-off and some other external stuff too. Hopefully I'll be able to scavenge at least part of what is missing from that carburetor.
Also, does anybody know what this linkage is? (Again, see below...) From what I've seen the stock mechanical linkage lets the center carb open most of the way, and only opens the end carbs near WOT. This linkage looks like it opens all of them equally... I this some hillbilly stuff or an all-out race linkage?
I'm thinking for starters I'll need to order the carb rebuild kits, fuel lines, filters, brackets, and mechanical linkage kit. The water neck appears to be incorrect so I guess I'll need one of those too. What else am I missing?
Matt Wieczorek
1966 Bonneville Hardtop Coupe (family cruiser that we take to car shows)
1967 GTO hardtop, 400HO, 4 speed (don't ask, its a basket case)
1973 Grand Prix SJ (currently doing a rolling restoration)
Trying to find that "sweet spot" between Roadkill and Concours d'Elegance
Old 09-30-2022, 11:27 PM
The linkage is either EELCO or one of the other brands of after market linkage. Hard to tell what the carb is off of.
Old 10-01-2022, 03:38 PM
flat-bill flat-bill is offline
Default tripower
Try these guys for parts, info and tune suggestions. Very helpful. Also the water neck is wrong but I think available as a repro.
https://pontiactripower.com/
Old 10-01-2022, 04:08 PM
There are 3 different water necks available from Ames depending on what car you want to use the manifold on. They have left. right and straight discharge angles.
Old 10-01-2022, 07:26 PM
Tom Vaught's Avatar
Boost Engineer
64 Waterneck pointed towards passenger side of vehicle.
65 Waterneck pointed straight up and was shorter in height.
66 Waterneck pointed towards driver's side of vehicle.
Your waterneck is none of those.
Tom V.
Old 10-01-2022, 10:30 PM
GtoFM's Avatar
GtoFM GtoFM is offline
Your throttle linkage is missing the trunnion clamp that is used to adj. when the end carbs come in. Time to upgrade the linkage?
X2 on Pontiac Tripower, Mike and John are very helpful.
Also ck with Dick Boneske, member.
The Following User Says Thank You to GtoFM For This Useful Post:
Old 10-01-2022, 10:44 PM
tom s tom s is offline
Not a tripower water neck at all.Tom
Old 10-03-2022, 06:13 PM
ftwmlp's Avatar
ftwmlp ftwmlp is offline
I think I have a reproduction 66 water neck purchased from Ames that I will gladly give you if you are interested (and I can find it)
I am attaching some pics of the linkage and other views I found for reference a few years ago when I first purchased my car (since decided to use "original AFB")
ID:	599902   Click image for larger version
ID:	599903   Click image for larger version
Fort Worth/Dallas TX area
1966 GTO Fontaine Blue
389 CID Carter AFB
Muncie 4 speed (orginally an automatic car)
Old 10-17-2022, 08:39 PM
Dick Boneske's Avatar
The end carbs are definitely real Pontiac Tri-Power units. The front one is a 1964-1966 carb. The rear one is a 1959-1963 carb. They are similar in appearance and identical in operation and performance.
The center carb is not a '66 Tri-Power carb, but perfectly usable for your Tri-Power.
I can supply the choke pulloff & brackets, fuel filter and bracket, fuel lines & fittings, factory mechanical linkage, waterneck, choke stove for manifold, and the kits to rebuild the carbs (all three kits are the same for your setup).
You can personal message me for details and more info.
I also do restorations of Tri-Powers, and can color your carbs by the zinc dichromate process (the same as the factory did), rebuild the throttle bases, plate all steel levers and rods, assemble the carbs using all now consumable parts (accelerator pumps, needle/seats, jets, gaskets, and calibration to your engine (cam, cubic inches, accessories, etc.)
ID:	600643   Click image for larger version
Name:	'66 Tripower, Fall Colors 011.jpg
ID:	600644   Click image for larger version
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 12-24-2022, 07:56 PM
Tom Vaught's Avatar
Boost Engineer
My vote Sir, would be to send the intake and carbs to Dick B, above, as he does outstanding work with the correct carb dipping (coloring) vs a paint job rebuild.
Tom V.
