Tri-Power Tech 57-66 Tri-Power Talk
Old 01-11-2023, 10:56 AM
bob d bob d is offline
Default carb to manifold gasket install
is there a side of the gaskets that go towards the carb? I thought the part no. side was toward the carbs but not sure. Thanks.
Old 01-11-2023, 11:28 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Mine look the same on both sides, makes no difference. Are yours different?
Chris D
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60'
Old 01-11-2023, 11:56 AM
On the end carb gaskets no. 60113 there seems like an indented design around the holes on the side of the part no. They were on the car when I got it. I have new ones coming today I will see what they look like.
Old 01-11-2023, 12:59 PM
Kenth's Avatar
Kenth Kenth is offline
As long as the side with the #60113 is between the rear studs, all is fine.
#īs towards carb or intake does not matter.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-11-2023, 01:33 PM
Default carb gaskets
The new gaskets arrived today. Flat on both sides so it doesn't matter. The old gaskets must be originals much better quality. No part no. on new gaskets. Thanks for your help.
