Old 04-16-2023, 07:21 AM
Jeff Hamlin's Avatar
Exclamation COMING SOON...
Old 04-16-2023, 10:45 AM
OG68 OG68 is offline
2007 Cadillac SRX
Old 04-16-2023, 10:07 PM
694.1 694.1 is offline
Yes!
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 04-18-2023, 06:51 AM
Arrow ENGINES;
1968 / 9790**, ZN, 1BC-A.T. (SPINS) $300 OBO
1968 / 9790**, ZN, 1BC-A.T. (STUCK) $150 OBO
1967 / 9787**, ZD, 4BC-A.T. ( ¼ TURN) $700 OBO
1966 / 9782**, ZE, 4BC-A.T. (POSS RUNNER) PENDING.
ID:	610943   Click image for larger version
Old 04-20-2023, 06:10 PM
Arrow 1968 / 9790**, ZN, 1BC-A.T.
$300 OBO
Rotates Freely.
Sold As Is,
No other parts for this engine.
You arrange for pick up/shipping.
ID:	611066   Click image for larger version
ID:	611067   Click image for larger version
ID:	611068   Click image for larger version
ID:	611069   Click image for larger version
Old 04-20-2023, 06:15 PM
Arrow BELL HOUSING & FLYWHEEL
used on 1966 1967 1968 & 1969 Tempest, Lemans, and Firebirds with manual 3 or 4-speed transmissions.
Bellhousing has a minor chip on the bottom.
Flywheel has been cut and no longer has the factory step.
This should not pose any issues with resurfacing and using it.
Sorry, no inspection cover.
$225 plus shipping for both.
Old 04-20-2023, 06:18 PM
Arrow POWER STEERING MOUNTING BRACKET WITH HARDWARE AND BRACE.
Used on all OHC 6 1966 1967 1968 and 1969 engines with PS.
These little brackets are truly getting hard to find.
Most I see online are usually broken.
$175 Plus Shipping.
Old 04-20-2023, 06:21 PM
Arrow 1966 4BC HEAD
1966 CYLINDER HEAD FOR THE FOUR BARREL ENGINE aka SPRINT.
$200 Plus Shipping
Old 04-20-2023, 06:26 PM
Arrow 1966 Pontiac OHC 6 Aluminum Timing Belt Cover.
This is a ONE-year-only piece.
I only have the top cover piece no other parts of the belt cover.
$200 Plus Shipping.
Like the Aluminum Camshaft Housing, this cover can be polished to a high shine and looks outstanding when done. Thus why you can't find these to easily.
Will fit on all 1966, 1967, 1968, and 1969 OHC 6 engines with the correct bracket.
Old 04-21-2023, 06:16 AM
Default 1967 4 BARREL INTAKE & EXHAUST MANIFOLDS
The heat Gate was removed but otherwise in good condition.
This will bolt on to all Pontiac OHC 6 Heads; 1966, 1967, 1968, 1969.
$375 plus shipping.
Old 04-21-2023, 06:24 AM
Arrow 1966-1967 4 BARREL CAMSHAFT
I have this on file as used on both 1966 & 1967 4BC engines.
#9792538
Still mounted in Cam House and Lobes are in really nice shape.
$250 Plus Shipping
Old 04-21-2023, 06:38 AM
Arrow 1966-1969 ENGINE MOUNT FRAME BRACETS
Used on all A-Body Models
$100 Plus Shipping
Old 04-21-2023, 06:47 AM
Arrow 1967-1968
Duel Groove-2 Belt Fan Pulley.
$75 Plus Shipping
Old 04-21-2023, 06:49 AM
Arrow AUTOMATICE TRANSMISSION FLEX PLATE
Used on all AT engines.
$100 Plus Shipping
Old 04-21-2023, 07:23 PM
Arrow 1967 4BC ENGINE
1967, 9787**, ZD, 4BC (aka SPRINT) W/ Manual Transmission.
This is a true barn find and will need a complete overhaul.
Engine Rotates.
$650 Your arranged pick up/shipping.
Thanks.
Old 04-23-2023, 05:12 PM
Exclamation CORRECTION;
The 2-belt pully is a 1966 fan W/PS App.
I have single Belts Pullies as well.
Thanks.
Old 04-25-2023, 07:03 PM
Arrow 1966 4BC MANIFOLDS
The center divider is hogged out, but as mentioned in another post would work but likely be a heavy drinker. Better suited for an EFI setup.
Anyhow what you see is what it is.
$125 Plus shipping
Old 04-25-2023, 07:08 PM
Arrow 1967 Duel Groove Power Steering Pump Pulley
For use on models with AC.
$60 Plus Shipping.
Old 04-25-2023, 07:14 PM
Lightbulb 1967 POWER STEERING SINGLE GROOVE PULLEY
Could work on other years as well.
$30 Plus Shipping.
Old 04-25-2023, 07:18 PM
Arrow 1966-1967 PISTON RODS
6 PACK.
$50 PLUS SHIPPING
