Old 09-11-2023, 12:04 PM
performerrpm's Avatar
Default hiding a 871 under the hood ...65 gto
i coukd have swore i seen a youtube vid of a guy with an 871 under his gto hood...cant find it...anyone tried to get one to fit under a 65 with 4inch cowl..?
Old 09-11-2023, 01:40 PM
misterp266's Avatar
“Ain’t no way”
Aretha Franklin
" Darksiders Rule "
The Following 2 Users Say Thank You to misterp266 For This Useful Post:
Old 09-11-2023, 02:02 PM
tom s tom s is offline
Maybe a 653.Tom
Old 09-11-2023, 09:07 PM
i set it all up this evening, even without the carb adapters my 4" hood just aint enough
Old 09-11-2023, 11:53 PM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
What about electronic injection with custom low-rise throttle bodies?
Old 09-12-2023, 12:09 AM
Stuart's Avatar
Stuart Stuart is offline
Maybe some side draft carbs, like a Latham setup?
Old 09-12-2023, 12:33 AM
242177P's Avatar
242177P 242177P is offline
https://www.youtube.com/watch?v=R2-07ZzhQWA
Old 09-12-2023, 01:16 AM
Sirrotica's Avatar
There's this X 400 showcar built to fit under the hood of a 63 GP. It would be a challenge to use 4 sidedraft carbs on a custom built intake to fit the top of a GMC blower. The throttle linkage would be a challenge for sure, but it fits under the stock hood. I believe that blower is a 671, but the snout could be shorter to fit an 871. Notice 7, V belts to drive the blower instead of a cogged belt.
If you wanted a blower under the hood, and were willing to use a Magnuson, or Whipple style blower, and went with electronic FI, it shrinks the package down considerably. This is a 2004-06 late model LS GTO with a Magnuson blower that fits easily under a stock hood. it's not an 871, but it's in a package that is much easier to fit under a stock hood.
I didn't find any 65 GTOs with a 871 blower under even a 4 inch bubbled hood when I searched the net. That big chunk of aluminum is going to be difficult to disguise under most any hood after the late 50s cars. I've seen 55-57 chevys with a blower under the hood, but the hood is quite a bit higher than a GTO hood.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 09-12-2023, 01:59 AM
Put a flat hood on your car and cut a big hole in it.
Show your 8-71 to the world, that’s the right way.
Old 09-12-2023, 10:33 AM
Wait for someone to make a pontiac screwtype blower system!Tom
Old 09-14-2023, 09:48 AM
i82much's Avatar
i82much i82much is offline
is there a way to safely drive in the rain if you do that?
Old 09-14-2023, 10:46 AM
My hobby cars are all used in fair weather, none get driven in the rain whether or not there’s a blower sticking out of the hood.
That’s what my late model modern cars are for, I’d rather one of those get in an accident on a slick road than one of my old cars I have invested a lot of time and money.
There are guys who drive old hot rods in every kind of weather with the engine completely exposed so it’s not like you can’t drive in the rain. So as long as you don’t mind the cleaning afterwards have at it.
There are dozens of ways to add boost that will package nicely under the hood but a GMC 8-71 roots blower really isn’t one of them. They’re traditionally exposed through a hole in the hood, pretty much meant for displaying as it should be.
Old 09-14-2023, 03:40 PM
misterp266's Avatar
This. ^ ^ ^ !
One of the reasons to run a roots blower is the awesome look!
Don’t hide it!
i82much; is there a way to safely drive in the rain if you do that?
Take the cheater slicks off and stay out of the throttle!
" Darksiders Rule "
Old 11-16-2023, 01:16 PM
74mula's Avatar
74mula 74mula is offline
I went with EFI and the BDS intake and fit my 8-71 under the hood. A 4 inch cowl would hide the bug catcher also.
Old 11-16-2023, 03:24 PM
Keith Seymore's Avatar
“Ain’t no way”
Aretha Franklin
'Retha knows a lot about cars.
At least, compared to most gospel/soul artists.
K
'63 LeMans Convertible
'63 Grand Prix
Old 11-16-2023, 06:53 PM
krisr's Avatar
krisr krisr is offline
A newer TVS 2300/2650 blower would probably come close to fitting if someone had the time/money/energy to either get a manifold cast or sheet metal one made. Would make a crap load more power and have cooler air temps too. A few of us were going to approach Harrop Engineering in Australia as they are now making manifolds for new blowers to go on conventional V8's like SBC/BBC atm. I heard a Pontiac manifold has come up in discussions with their R&D dept, but not sure if it was green lit.
Old 12-24-2023, 01:46 PM
darbikrash darbikrash is offline
Default Pontiac twin screw blower
Taking names now for an interest list.
https://forums.maxperformanceinc.com...92#post6474692
1964 Catalina 2+2 4sp, 421 Tri-power
1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM,
Holley EFI, DIS ignition.
1969 GTO 467, Edelbrock 325 CFM, Terminator EFI
1969 Firebird Convertible
Old 12-24-2023, 07:54 PM
Big Bear's Avatar
Big Bear Big Bear is offline
Dont need a hood https://www.youtube.com/shorts/prREX...?feature=share
