Old 12-31-2005, 02:20 PM
P@blo's Avatar
P@blo P@blo is offline
Thumbs up
Cliff, hats off to you as experienced members such as yourself and Jim Hand are a total asset to us guy's starting out and appreciate all the information you have shared through your testing.
Happy New Year
Brent
  #42
Old 12-31-2005, 03:44 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Cliff- maybe KRe could market "your" HD roller as a purchased item??
John
  #43
Old 12-31-2005, 04:00 PM
Armadillo Armadillo is offline
Cliff,
Thanks for all the testing that you do. It helps us all out.
Tom
  #44
Old 12-31-2005, 06:16 PM
Cliff R's Avatar
Cliff R Cliff R is offline
Thanks all, getting late, been a long day, I actually took the day off and went rabbit hunting with some old friends from High School. I've got a new bottle of single malt Scotch to try out this evening, gonna forget all about engines, cams, carburetors and other hobby stuff for a few hours!.....Have a great New Year!......Cliff
  #45
Old 12-31-2005, 06:29 PM
Kenth's Avatar
Kenth Kenth is offline
Cheers all!
35 minutes left of 2005 here in Sweden.
Have to finish off some leftover Christmas ale´s.
Happy new year!
  #46
Old 12-31-2005, 07:55 PM
Tom Vaught's Avatar
Boost Engineer
Drink one for me Cliff and I will have one for you.
Tom V.
  #47
Old 01-01-2006, 11:49 AM
Cliff R's Avatar
Thanks Tom, messed up and drank a few more for ya! Had a great evening, suns poppin out here and temps are going into the 40's today. I tried to call you at work and missed you a couple of times, when you get time, call me, got a few carb items to discuss....thanks....Cliff
  #48
Old 01-01-2006, 01:30 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Temp is 71 and so humid there's water on the concrete here still!
  #49
Old 01-01-2006, 11:17 PM
Cliff R's Avatar
Skip, I'll take 71 and humid over 40's and soggy. It's nothing but a big mud-hole around here, the snow melted and the ground thawed out. I wanted to get the Road King out today but the driveway is too soft and muddy......Cliff
  #50
Old 01-02-2006, 03:16 AM
krisr's Avatar
krisr krisr is offline
You guys are lucky! Our new years day here was 44°C or 112°F with only 9% humidity from about 11am till 10pm!!!
  #51
Old 01-02-2006, 01:11 PM
Ron H's Avatar
Ron H Ron H is offline
I like cold but, we are lucky? You live in Sydney... a really GREAT Port City !!
68 Firebird
Are you running with the wind or breaking it?
  #52
Old 01-02-2006, 05:28 PM
Skip Fix's Avatar
Well we set a new high yesterday of 81! Was a very nice day, humidity burned off later. Was sweating out in the garage tearing down the previous motor.
Was in the low 30s just 2 weeks ago.
  #53
Old 01-03-2006, 08:55 AM
Half-Inch Stud's Avatar
Cliff,
Can you describe the range of Total Advances tried (like how low a Total ADV can you go without loss of HP/TQ?, and can you describe the onset of PING noticed when the power was peaked?
I assume you used 93-94Octane Fuel. Is that correct>? HIS
  #54
Old 01-03-2006, 09:09 AM
Cliff R's Avatar
HIS, we use 89 octane in this particular engine for all testing, dyno and track runs. We've moved the timing a couple of times off of our 30 degree total setting and power either doesn't change, or falls off some. We tried a range of 28 to 34 degrees during the dyno testing the past couple of weeks, and also increased fuel octane a tad by adding about 20 percent 108 octane to our 89 octane fuel. The engine simply makes it's best power right at 30 degrees BTDC. Adding the race gas showed no improvements and increasing octane at the track has little if any impact of ET or MPH, it usually runs the same or slows just a tad.
During the past 4 years, I've heard the engine ping once, when we tried to test a stock Performer intake on it. When torn down for freshening up, all bearings were in perfect shape, not the first hint of detonation.
We saw the same thing back when we ran the 6X-4 heads, it likes/wants 30 degrees BTDC total timing. We bring it all in by about 2800rpm's. Since our converter stalls just above that rpm, the spark curve itself isn't a factor in track performance.
I have on a few occassions played around with the spark curve and adding some additional timing via the vacuum advance, ranging from about 10 to 20 degree's, hooked to either a ported or manifold source. It really doesn't make any difference in throttle response, fuel milage or power anyplace. We choose to use a ported source to the advance as the engine idles fine in and out of gear and add about 10 degrees of additional timing at cruise. The engine idles OK using a manifold source to the advance, but going beyond about 20 degrees timing induces a slight "skip" or miss into the engine. Probably due to the high compression ratio and small cam specs, it simply doesn't want or need that much timing at idle for best efficiency......Cliff
  #55
Old 01-03-2006, 02:36 PM
77TA 77TA is offline
Cliff can you post the dyno curves graphs of all three cams ?
I think that would be interesting to see side by side.
  #56
Old 01-03-2006, 03:36 PM
89 Octane & 30 degrees Total is a value we all could aspire towards.
What were the 60foots when using 30deg & 89Octane?
Well done. HIS
  #57
Old 01-03-2006, 10:48 PM
Cliff R's Avatar
HIS, earlier this year with a fresh set of MT ET Drag Radials all runs netted 1.65-1.67 60' times and ran 11.64 to about 11.80 depending on weather conditions. Later in the year, in much hotter weather, 60' times slowed to around 1.69-1.71, and the car slowed into the 11.80's to 11.90's. Even though we slowed up a couple of tenths, we ran MORE mph? When we pulled the engine down for freshening up, there was quite a bit of slack in the timing chain, everything else was fine.
I don't have the graphs from all 3 cams, just the dyno sheets.....Cliff
