Old 03-22-2006, 03:38 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Point was we had a head with at LEAST 310 cc -big bowl, big valves that still had 619 ftlbs @ 2500. Bowl size generally gets measured in the port cc.That's still a "tractor motor" bottom end torque in anybody's book, and still had all HP in by 6200 rpm, so not a high rpm motor. Shoot the Continental convertor flashes to 3000 where it had 622 ft lbs.. It needed the airflow to make those numbers.
And it's on a Pontiac bore spacing/head bolt pattern block, Pontiac intake,Pontiac headers for those guys that say it is only applicable if it's a "Pontiac".
  #182
Old 03-22-2006, 05:59 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Post
ok Slowbird, was thinking about the SC heads with the built in spacer. yes, the raised port and bowl area will add greatly to the overall port volumne.
yes, Skip agree with your point. the min CA, velocity, valve angles, chamber shape, and DEPTH of the chamber,(kaases) plays a big role in the lowend rpm engines.
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
  #183
Old 03-22-2006, 06:37 PM
Junkyard Dog's Avatar
Originally Posted by Bruce K
Skip, I still don't understand, the smaller solid roller cam has more dur at .050 than the larger adv. dur hydraulic cam, yet Lunati has lower proposed requirements. Do you think it's a typo or real?
hyd adv - 296/304, .050-dur 239/247, .507/.530", 4200-4500 stall, 11:1, 4.56
solid rllr 288/296, .050-dur 255/263, .626/.626", 3000-3500 stall, 10:1, 3.90
I do not know if anybody addressed this, so:
Solid rollers have a lower rpm torque for their .050 numbers than do hydraulic flat tappet cams.
Badder than old King Kong
-Jim Croce
  #184
Old 03-23-2006, 07:59 AM
taalltheway taalltheway is offline
Wow, what a thread...the giants of the Pontiac hobby at a fierce battle...one thing i would like to add: I would like to thank Jim Hand for being one of the few people that publish articles and books in the hobby that are not trying to talk you into buying all sorts of expensive aftermarekt parts. Jim has shown that the engineers of the factory were not completely dumb and that a well tuned "stock" engine can show very good results with low investments. His "tractorengine" is what most people need/want anyway.....
  #185
Old 03-23-2006, 09:03 AM
Cliff R's Avatar
Cliff R Cliff R is offline
"His "tractorengine" is what most people need/want anyway....."
Really? These tractors engines are VERY expensive! After installing ours we had to add subframe connectors, weld the axle tubes to the housing, drag shocks and custom leaf springs/adj pinion snubber. In addition we had to sump the tank/electric pump and run -8AN fittings/lines everywhere.
Did I mention we LUNCHED the TH400 on the second outing. How about grenading two 8.5 posi units in two trips to the track, not to mention twisting the stock driveshaft into a "pretzel".
To date we've spend over $1000 in different tires trying to hook this thing up, and a custom 10" converter ($500).....are you sure you really want one of these engines?
On a good note, once we upgraded everything behind the engine, the car runs well into the 11's in full street trim. About as easy to drive on the street as my daughters 2001 Nissan Sentra! At the track, we just lower the tire pressure from 24 to 18psi, and race. No cooling down required, 89 octane fuel, 15mpg's and it idles like a "stock" Ram Air III 400........Cliff
  #186
Old 03-23-2006, 09:34 AM
i82much's Avatar
i82much i82much is offline
Cliff you sound like you really regret it! You mighta got 23 mpg or so with your daughter's Sentra motor.....
  #187
Old 03-23-2006, 10:39 AM
Skip Fix's Avatar
Jim has done a great job finessing stock parts and has used good thoughts in all his modifications. I'll bet if Jim "paid" himself even minimum wage for all the tuning, porting, parts swaps, engineering on his car it would be anything but cheap, especially for someone that would have to pay someone else to reproduce it, but then we all spend time doing what we like for our hobbies.
The Pontiac engineers had such diverse combinations they came up with that even disagree with some of the thoughts here , how do you know which engineer at Pontiac had the good ideas? Different chambers and port CCs of the RA/SD heads, or the RAV huge ports, so there must have been some disagreement even among them!
  #188
Old 03-23-2006, 08:31 PM
Cliff R's Avatar
"Cliff you sound like you really regret it! You mighta got 23 mpg or so with your daughter's Sentra motor....."
Not really, but we got a real "reality check" after installing the engine, took about 2 years to really get the car to run the numbers we were looking for. It's usually that way with this hobby, easy to make the power, very difficult to effectively use it!
We really LOVE the entire "package", it let's us run a lot of "stock" parts and exhibit nearly "stock" engine/vehicle characteristics for "normal" driving. A quick glance at the car or listen to it, you'd think maybe high 13's at best? The thing I love about it the most, is the looks we get when folks wonder over and take a gander at it in the pits or staging lanes. The look on their faces when they see the iron intake and Q-jet.....PRICELESS!......Cliff
  #189
Old 03-23-2006, 09:39 PM
grandville455's Avatar
grandville455 grandville455 is offline
[QUOTE=Cliff R
..I know that look CLiff!! ... that and the how much does it weigh?,lol
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
  #190
Old 03-24-2006, 09:31 AM
Cliff R's Avatar
Darby, ever get "where's the nitrous"?......Cliff
  #191
Old 03-24-2006, 10:09 AM
Yep ...I especially like when they come over and say WOW This thing moves mUst have some deep gears in her huh,like 4.10's or something?...I say nope!! 3.23's!!! ...... The look is "PRICELESS" as u say
Darby
