Old 11-21-2020, 09:08 PM
tjs72lemans tjs72lemans is offline
Default headlight switch and cig housing bezel removal on Lemans
Do the headlight switch and cigarette housing bezels unscrew to take them off?
Old 11-22-2020, 05:01 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Yes
Old 11-24-2020, 12:01 AM
lust4speed's Avatar
The cigarette lighter has a full cap around it that unscrews from the rear allowing the main housing to slide straight out to the front.
The headlight knob and shaft are removed by releasing the button on the side of the switch and pulling it out. Then you can use the proper tool or a large screwdriver to unscrew the slotted headlight switch nut.
Mick Batson
Old 11-24-2020, 09:33 PM
Thank you.
