Old 07-10-2018, 06:35 AM
1966geeto 1966geeto is offline
Default Clock repair
Who does quartz clock repair 72 GP ?
Old 07-10-2018, 07:40 AM
Bentwheelbob's Avatar
Pete Serio. He’s a member here and does a great job.
http://precisionpontiac.net
Old 07-10-2018, 09:11 AM
Keith Seymore's Avatar
(Not to take anything away from Pete, but) If you are inclined to try it yourself you can contact these guys and see if they have a quartz kit:
https://www.clocksandgauges.com/
It's kind of satisfying to fix it on your own; Just make sure the kids and the dog are not around when you do the upgrade, because it does take some focused attention.
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
Old 07-10-2018, 05:13 PM
David Brown's Avatar
David Brown David Brown is offline
Send a message via ICQ to David Brown
Or Instrument Services www.instrumentservices.com
Old 07-11-2018, 10:46 AM
mr67gp mr67gp is offline
Or Bob's Speedometer. I had my '57 speedo rebuilt be them last month. Quick service. They advertise that they do clock conversions as well.
https://www.bobsspeedometer.com/1/120/index.asp
Jim K in PA
1967 GP HT 428
1967 GP convert 428
1957 Chieftain 4D HT
Old 07-11-2018, 11:51 AM
Stuart's Avatar
Stuart Stuart is offline
If you decide to replace the whole thing, Ames has one listed in their catalog that is equipped with a modern quartz movement.
Old 07-13-2018, 05:58 PM
63gpman's Avatar
63gpman 63gpman is offline
or, try cleaning the one you have. Take the thing apart, spray the back of it with electrical cleaner, turn it several times, spray again. Sand down the points contacts, spray with your favorite lube (WD or other spray lubricant) Turn it several times and see if it works. I have had great luck cleaning them.
Brad Hansen
65 Cat Ventura, 66 Cat Vert, 63 GP
Old 07-14-2018, 07:02 AM
If you want a bone stock clock, that the second hand clicks one second at a time (as opposed to just constant, even movement) then clean and fix it. But quartz clocks are dead on accurate. They don't add or lose time. It is nearly impossible to get the factory movement anywhere close to accurate. It needs reset a couple minutes regularly.
Old 07-14-2018, 07:10 AM
stevep's Avatar
stevep stevep is offline
I used to fix my clocks by removing the bulb and spraying WD 40 inside and tapping them. That was it & 90% worked after that.
Old 07-11-2020, 03:19 AM
Bob Timmermans's Avatar
Bob Timmermans Bob Timmermans is offline
Exclamation Fire hazard !
I know this is a older post but for future reference , be careful with just spraying thrue the bulb hole !
I took the clock apart on the bench like 63gpman suggested and sprayed it and blew it clear several times , then sprayed it again and hooked it up to a battery.
It started to run , so I figured let it run for an hour or so , but within seconds it started to smoke.
Ripped the contacts loose really fast so no harm was done.
The abundance of lube on the mechanisme caused a short circuit.
On the bench you can blow the greater part of the lube out and be done with it , but if this happened in your car you could end up burning everything down.
These old electrics keep giving me the creeps.
Cheers , Bob.
Old 07-11-2020, 09:49 AM
burd's Avatar
burd burd is offline
Bobs Speedo has the kits, do it your self. It’s easy.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here
Just Say No To 8” Flakes
F ire B irds
Thread Tools
Display Modes
