Old 11-14-2020, 10:16 AM
lemans67 lemans67 is offline
Default 3/8 or 1/2 in hog rings?
Getting ready to tackle the seats in my 67 LeMans. I wanted the better tools, so I did not order the pliers or rings with the kit. What size rings are used on these cars? Thanks.
67 LeMans convertible. Tyrol blue, M22z autogear, 2.73 8.5, 455, FAST MPI fuel injection. 243/ 251 112. solid roller. SD performance ported 6x heads.
Old 11-14-2020, 03:14 PM
tempest1964's Avatar
There is a person on this forum who goes by Rambow that seems to be pretty well versed in interiors. He sell parts too. If you pm him, I’m sure he would be happy to answer any questions that you have.
Old 11-23-2020, 07:19 PM
rambow rambow is offline
3/4" hogrings are the standard size for upholstery work.
I prefer the Osborne No. 1440-C hogring pliers.
The "C" have the nose bent forward which greatly helps reaching inside the listing channels in the buns.
I have all three variations (A-Straight, B= nose bent sideways, C=nose bent forward) but I find that I use the "C" for almost everything. now and then i'll find the "A" straight ones are helpful for a weird spot... I almost NEVER use the "B" sideways bent ones.
https://www.amazon.com/C-S-Osborne-P.../dp/B075VD91GL
For cutting hogrings off... 8" bolt cutters are your best friend. 1000x better than regular side cutters or dikes that will shock the hell out of your hand every one you cut...
https://www.harborfreight.com/8-in-b...ter-57221.html
The Following User Says Thank You to rambow For This Useful Post:
Old 11-24-2020, 04:07 AM
dataway's Avatar
dataway dataway is offline
Just ordered the Osborne pliers and some 8" Knipex bolt cutters.
Would you experienced professionals stop recommending things, I'm going broke
Old 11-24-2020, 04:47 AM
OG68 OG68 is offline
Your wrists will thank you as well as well as your hands.
2007 Cadillac SRX
Old 11-24-2020, 10:38 AM
dataway's Avatar
When it comes to the pliers I was hesitating because of the price, then I got to thinking that hog rings could come in very handy around the property ... never even considered them before, would come in handy for the vineyard, fences etc.
I absolutely hate the "SNAP" when cutting large diameter wire with the tip end of side cutters, so the bolt cutters are another tool I should have bought long ago.
Old 11-24-2020, 11:51 AM
Rambow is the man!
The Following User Says Thank You to tempest1964 For This Useful Post:
Old 11-24-2020, 11:54 AM
The Osborne pliers listed are very nice, I also ordered 3/4in rings and some small bolt cutters on Amazon. Originally started with 1/2, but I can see that the larger ones would be better. I started attaching the burlap and foam for the bottom. The backrest part seems more difficult. Now waiting on free time.
The Following User Says Thank You to lemans67 For This Useful Post:
Old 11-24-2020, 05:00 PM
Yeah i find myself using hogrings for all kinds of stuff, just because they are sitting here!
Another good tip... I find myself twisting off the old hogrings when stripping stuff is quicker than cutting them. I still use the bolt cutters for the twisting action too, that way i can quickly cut them if they are a problem. The only exception to trying to twist is when the metal is badly rusted or thin (like the metal tabs on the bottom sides of bucket seats) then i'll always cut as to not risk tearing the metal tab.
the other advantage of twisting them off is you don't wind up with as many tiny peices of rusty hogring all over the place to clean up.
Old 11-24-2020, 06:15 PM
vertigto's Avatar
vertigto vertigto is offline
Funny...that's what I found to be the best method when I was tearing apart my seats, but thought I was an anomoly.
