Old 12-13-2003, 07:39 AM
Grr8one's Avatar
Grr8one Grr8one is offline
I have a 1976 400 and need a oil pump drive rod.I bought a melling from a local auto store.It has 2 notches which doesnt allow it to drop all the way down.Can these filled off or does anyone know about this. Thanks
[This message was edited by Brett Wray on December 13, 2003 at 09:49 AM.]
Grr8one's Avatar
Old 12-13-2003, 09:26 AM
Filing or grinding off the two 'notches' is commonly done when installing it from the top since that's the only way it will go in from up there.
It is usually installed from the bottom but some builders forget to put it in before the oil pump and oil pan go on, hence the fairly common removal of the offending 'notches'.
Welcome to the PY forums.
Some say the glass is half full, others say the glass is half empty...I say 'Are you gonna drink that?'
www.outlawpontiacs.com/members/B-Man2.php
www.outlawpontiacs.com/members/B-Man.php
Old 12-13-2003, 11:32 AM
WDCreech's Avatar
WDCreech WDCreech is offline
I've only forgotten to put the oil pump drive in, before the oil pump, once. Like b-man said just grind off the tangs. Be sure to clean it thoroughly before you install it.
Bill
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
8.2550@164.17-1/4, 5.2901@131.97-1/8, 1.1981-60-ft. 8/10/08
