Air/fuel ratio
The wide-band A/F-ratio meter temporarily (?) installed in my '59 GMC (382 c.i. '58 Tri-Power engine) has been extremely useful in tuning for cruise, deceleration, and idle conditions- consistently very close to 14.7 now. But I recently made a point of paying attention to it during full-throttle situations (all four gears, varying speeds). I'm a little bit surprised to see it generally in the high twelves, considering how well it performs. I had thought it would need to be at least down into the elevens to not ping or otherwise misbehave. Anybody have any experience to compare with?
I also included runs on just the center 2-bbl. The full-throttle A/F ratios were amazingly close to what I saw with all three carbs.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
Is the current jetting/calibration far from the original factory jetting?
I've tested LOTS of cars on my chassis dyno. Best power for naturally aspirated motors is almost always right about 12.8:1. Best idle is usually 14.0:1.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust My webpage http://lnlpd.com/home |
11.5 to 1 is a Boosted Engine Air/Fuel ratio. Tom V.
Thanks guys. That makes me more comfortable with what I'm seeing. Hard to believe how closely I guessed on main/power/pump systems! However, trying to tune the idle of this almost-over-cammed street engine by ear was a disaster- letting off the throttle while cruising showed about 11:1 A/F!
I would like to jump in here.
I am tuning mine as well. I have 12.5 at 2500 rpm and about 14.7 at idle. However, deceleration I am up to 16.5. . Is this OK.?
........I'm just learning as I go....... |
14.7 at idle, and 16.5 on deceleration are fine.
What is the engine load with the 12.5 at 2,500 rpm? If it's no-load or light load (cruising on level road) I'd want it leaner than that- maybe 13.5 or so.
Good point Jack, I am at idle in the driveway now.
Thanks. I am loving this A/F meter, I should have got one years ago.
