Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
87 chevy starcraft van parking brake not popping back
this is actually for my 87 chevy starcraft van im going to sell...the parking brake pedal doesnt pop all the way back still leaving the parking brake partially engaged...when i release my firebirds parking brake it pops back so hard it could almost hurt you...lol...with the van i have to go under the van and give the cable a tug...adjusting doesnt help...i guess the springs inside the rear hubs are worn as well as the springs under the van have lost their spring?
is there any way to add helper springs or spacers to add more tension so the rear brakes release or do i have to go through the pita of changing the rear cable?
'74 formula 400, w/shaker (3 scoops) black deluxe interior, '70 406 balanced assembly, .30 trw slugs, moly rings, 4x heads 2.11/1.77 stainless valves, ra 4 cam, e-rpm intake, holley 750 vac. sec, msd hei, hooker headers w/ dual 3'' flowmaster 50 series ending at axle, t400 w/ GM6 convertor, transgo shift kit, b&m starshifter, 3.08 gears, centerlines, 265/50-15 bfg's rear and 235/60-15 front...yes im over cammed but it is still very fun... |
First things first, check the pedal assembly and make sure there are no foreign objects in it. If there is a spring, check that too. Now as long as the cable is attached, it'll probably work. It may need adjusting but not replaced. Before you adjust the cable, and as long as you haven't found the problem already, pop the rear drums off and hose(yep, garden hose) out the drum housing. While the drum is off, check that all springs are in place. Have a friend try the e-brake while you check out the motion(wear safety glasses) PB blaster works great if not used in excess in this instance. You don't wan't it on the brake surface, but you can use it on all moving parts of the e-brake system. Go ahead and soak the adjuster(cable) with the PB, just in case. Hope this helps...
"Trust me friend, a hundred years goes faster than you think." -Kenny Chesney "Go fast, turn left, hang on, go straight, go faster...who wouldn't wanna piss off 900 angry horses?" 1967 Pontiac Firebird 400 Coupe 1966 Chevrolet Corvair Monza 110 Convertible 1965 Oldsmobile F85 Cutlass 350 HO Coupe, soon to have Olds 403 1970 Chevrolet Nova 383 Coupe, NEW! 2007 GMC Sierra 5.3 Z71 Ext. 2007 GMC Yukon 5.3 SLT |
thanks ior the info...i tried all that as well as taking apart an assembly to compare to at the pick in pull yard...when i had a rear hub replaced from the pbrake sticking the guy who had been doing brakes for 17 years at midas said he couldnt get it to adjust...i usually do the brakes but i was on a road trip when that happened...there is just no pop to it ...
Did you get a friend to help you pop it?
not yet...i understand though...so i can actually watch the parts to see what isnt happening...i just think the springs have lost their spring...ill give it a go agin this weekend...id rather be working on the firebird but i gotta get rid of this thing...
Absolutely! Yep, that's what it sounds like to me...
First Guess: Cables binding in the cable housings. High friction within the cable assembly. Common as dirt. Had to replace the cables on my '88 Silverado work truck.
DO NOT adjust the cables so tight that the shoes don't return to the anchor pins. Adjust the service brakes FIRST, adjust the cables if needed afterwards--generally the park brake adjustment is just fine once the service brakes are properly adjusted. |
