Old 11-21-2010, 08:08 PM
Matt Meaney's Avatar
Matt Meaney Matt Meaney is offline
great documentation pics. thanks for sharing.
  #42
Old 11-21-2010, 11:06 PM
muscle_collector's Avatar
muscle_collector muscle_collector is online now
those are some really killer gp's. thanks for posting all the eye candy for us.
  #43
Old 11-22-2010, 07:17 PM
pontiac6269's Avatar
pontiac6269 pontiac6269 is offline
Awesome GPs, you guys are killing me, I want to get a 69-72 GP again so bad.
Eric
1969 GTO - 461, turbo 400, Continental 13", 3.08 gears. - 12.59 e.t. @ 108.43 mph, 1.898 60'
1978 Oldsmobile Cutlass Supreme- 461, turbo 350, PTC 3500 converter, 9" 3:50 gears. = 11.39 e.t. @ 117.55 mph, 1.599 60' on E85
  #44
Old 11-22-2010, 11:40 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Default Just confirmed that fan belts are original...
Just pulled the car back in the garage a little bit ago... the engine stopped at just the right place to see all three fan belt numbers. The two letter code on each match the corresponding boxes on the build sheet. Look at boxes 36, 37 & 38 on the build sheet...
ID:	225558   Click image for larger version
ID:	225559   Click image for larger version
ID:	225560   Click image for larger version
  #45
Old 11-23-2010, 08:04 AM
2002Z4CSS's Avatar
Great looking car!
1971 Pontiac GT-37
  #46
Old 11-23-2010, 09:45 PM
GpFreak's Avatar
GpFreak GpFreak is offline
Thumbs up Original, Original
Very cool.
Steve Naresky
  #47
Old 11-24-2010, 01:52 AM
Keith Vrabec's Avatar
Keith Vrabec Keith Vrabec is offline
It's so cool that a lot of GP's out there still haven't been messed up. This is a great "pattern" for all our cars. Thanks a lot Grant for great pics and info.
  #48
Old 11-24-2010, 09:08 AM
robz's Avatar
robz robz is offline
Quick, pull them off b4 they snap in 2....:-)
1969 GTO 400-4speed, H/T
1969 Grand Prix SJ
  #49
Old 11-25-2010, 12:09 PM
428ho4spd's Avatar
Probably a good idea, but they aren't cracked and don't make noise so I'll just leave them be for now...
  #50
Old 11-25-2010, 12:21 PM
428ho4spd's Avatar
Default original heater hoses...
I don't believe that I've ever seen this before on an a/c car... the hose from the nipple on the right rear head to the control valve is a molded hose with a 90 degree bend off the nipple like the non-a/c cars used. In the last photo you can see a faint green stripe on it...
ID:	225786   Click image for larger version
ID:	225789   Click image for larger version
ID:	225790   Click image for larger version
ID:	225791   Click image for larger version
  #51
Old 11-25-2010, 01:54 PM
i thought they all came that way.
  #52
Old 11-25-2010, 06:11 PM
chicagoland chicagoland is offline
Woo, great pix! The blue GP looks like it's only 1-2 years old, a time travel back to '72 California family vacation for me!
  #53
Old 11-27-2010, 06:14 PM
joegpho joegpho is offline
Grant - great find!
Richard - look for a PM from me.
  #54
Old 12-13-2010, 03:34 PM
428ho4spd's Avatar
Default found another build sheet...
Started in on the interior yesterday, I pulled the rear seat bottom out to vacuum under it. Was pretty clean under there... just a little debris and a 1983 dime. There was another build sheet folded in half lying loose inside the seat bottom. Looks like it was just tucked under a spring loop originally and probably fell out when someone sat back there. Nice to have another copy to put into a sleeve. Also, I spotted a carpet trim tag attached to the passenger front section of carpet while vacuuming under the front seat...
ID:	227918   Click image for larger version
ID:	227919   Click image for larger version
ID:	227920   Click image for larger version
  #55
Old 12-14-2010, 07:55 AM
2002Z4CSS's Avatar
Wow nice mint build sheet.
1971 Pontiac GT-37
  #56
Old 02-03-2011, 01:53 AM
428ho4spd's Avatar
Default Back at it today...
Pulled the radiator and heater core to rebuild/replace. I needed to change the front crank seal as it was puking oil badly and has been for a long while, nice & easy access with the radiator out. I popped out the original crank seal and got my flexible scope to peek up into the timing case to check out the cam gear... as I had suspected its the original, aluminum & plastic with chunks missing! More work! Got the water pump and timing cover off and then took a few photos. A few plastic gear chunks in front of the main cap. The cooling system looks very clean.
Grant
ID:	233263   Click image for larger version
ID:	233264   Click image for larger version
ID:	233265   Click image for larger version
ID:	233266   Click image for larger version
  #57
Old 02-03-2011, 01:59 AM
428ho4spd's Avatar
Default a few more...
VIN stamp on block. Timing chain case is very clean... no corrosion, even on the divider plate and the sleeve seals slid right out. Fuel hoses on pump may be original too?
Grant
ID:	233268   Click image for larger version
ID:	233269   Click image for larger version
ID:	233270   Click image for larger version
ID:	233271   Click image for larger version
  #58
Old 03-18-2011, 11:34 PM
428ho4spd's Avatar
Default update...
Got a lot done over the past couple of months...
Had the original speakers restored and the AM radio works great. Removed the clock and took it apart to clean the movement and it now works. New timing gear installed along with new water pump and t-stat. Had the original radiator re-cored, new upper & lower hoses and a new heater core. Got the heater & a/c system working and the TCS system working with an nos three prong temp switch.
I ended up having the original rear plastic valance repaired and repainted, also had the front headlight surrounds and front valance stripped and repainted at the same time. Everything came out good and matched pretty well.
Next will be to have the driver's seat repaired, waiting on material from SMS. Then a full interior cleaning and conditioning. After that I will start in on the engine compartment... a good cleaning, install new valve cover gaskets, spark plugs and probably a carb rebuild.
Here's a few quick exterior photos taken yesterday...
ID:	238491   Click image for larger version
ID:	238492   Click image for larger version
ID:	238493   Click image for larger version
ID:	238494   Click image for larger version
  #59
Old 03-19-2011, 08:48 AM
cutrone's Avatar
cutrone cutrone is offline
WOW ! you have been working hard ..
Looks great , The white top really looks sweet on that car .
I know you will enjoy cruising it around .
Time to get mine out of winter hibernation .....
69 Grand Prix 428 H.O. loaded "J"
11.51 @ 116
  #60
Old 03-19-2011, 04:02 PM
is that a black or a dark blue vinyl top? i really love that color blue.
