Old 05-29-2012, 06:06 PM
For 800 I would
former." --Albert Einstein
- Winston Churchill
Old 05-30-2012, 01:19 AM
gthmcty1's Avatar
gthmcty1 gthmcty1 is offline
Okay guys thanks for all of your input I ended up picking up the car for $675 with $50 to tow to my pad!!! I talked to Triple AAA it will cost me $87 to get it registered and pink slip issued in my name!!! SO I am pretty stoked!!
Time to start on my "project"!!
Old 05-30-2012, 12:39 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Well, you certainly bought it right! Have fun with it.
Old 05-30-2012, 02:08 PM
You stole that one!
Can't wait to hear if it runs. At that price it doesn't matter.
- Winston Churchill
Old 05-30-2012, 02:24 PM
gthmcty1's Avatar
Thanks alot I am looking forward to it!
Originally Posted by mike nixon View Post
You stole that one!
LOL Mike your right, hopefully she will be "cooperative" LOL! Will keep you guys posted
Thanks again everyone!
Old 06-01-2012, 10:12 PM
Keith Vrabec's Avatar
Keith Vrabec Keith Vrabec is offline
We have taught the young Skywalker well......
I expect some beater burnout pics and a YouTube link shortly.
Old 06-01-2012, 11:51 PM
Jack Peters's Avatar
SJ's did not have pw & ps. Optional. Had one with neither.
JLP
Old 06-02-2012, 10:05 PM
GpFreak's Avatar
GpFreak GpFreak is offline
Post
Has some scratches, the worst is near the top and another about the middle then some scattered light ones, chrome looks good though.
Steve Naresky
Old 06-03-2012, 12:14 AM
Ben M.'s Avatar
Ben M. Ben M. is offline
For the original price I wouldn't even have bothered. For $725 at the door, that's a deal even if it ends up not being able to get back on the road.
Old 06-03-2012, 11:43 AM
gthmcty1's Avatar
LOL, you got it Keith!!
Old 06-03-2012, 11:48 AM
gthmcty1's Avatar
Steve thanks for "digging through the barn" lol, does it have the hardware (tracks, rollers) at the bottom of the glass?
Old 06-03-2012, 04:01 PM
gthmcty1's Avatar
Steve thanks for "diggin in the barn" as I was cleaning out the car I found the "missing" window underneath a set of power window door panels that came with the car!! On another note I took of the valve covers and the carb, pulling off the valve covers I was surprised at how clean it was and this is on both sides!! The intake manifold had rust on the carb mount area but it looks to be contained to where the throttle blades were located looks as if water sat in there for awhile.
I also pulled the spark plugs and they were all burning correctly had that nice "brownish" red look to them.
I need to do some rewiring under the hood it looks as though the mice had a field day with the wiring does any one know where I can get a wiring schematic from for the GP?
Old 06-03-2012, 06:39 PM
gthmcty1's Avatar
How do you remove the shift knob from the floor shifter?
Old 06-03-2012, 06:40 PM
74 heads screw in studs, not a junk motor for sure, what's the code on the right front of the block. See if there is a 74 by the distributor hole.
You will need a 70 gp engine harness....LEmme look, not sure if I have anything good. I would expect that if it is a 74 harnesss plugged in to the firewall everything is goofed up. Need to start with the right harness.
Old 06-03-2012, 06:41 PM
Got to love the California exhaust manifolds...Betcha the bolts actually come out of them....No challenge....
Old 06-03-2012, 06:46 PM
gthmcty1's Avatar
Keith when you say right side are you referring to when I am standing in front of the car?
Old 06-03-2012, 06:47 PM
gthmcty1's Avatar
As a matter of fact.....YOU ARE CORRECT!! LOL
  #38
Old 06-03-2012, 08:08 PM
428ho4spd's Avatar
Best method is to release the lower snap ring under the knob first with a small pair of snap ring pliers (90 degree type work best for this) and move the snap ring down the shift lever a few inches. Then slide the knob down far enough to clear the button and upper snap ring. Then remove button, upper snap ring and washer. Then you can slide knob up and off shift lever.
Hope that helps!
  #39
Old 06-04-2012, 07:40 AM
engine code is on pass side of engine block near where the head, timing cover and intake manifold meet. look for two digits like YA or something like that
  #40
Old 06-04-2012, 07:52 AM
The Boss's Avatar
The Boss The Boss is offline
Nice deal - keep us posted.
And go racin' in the street.
