Old 01-18-2017, 06:08 PM
SD455DJ SD455DJ is offline
Going with larger valves, or sticking with stock? Dennis
  #62
Old 01-18-2017, 07:44 PM
footjoy's Avatar
footjoy footjoy is offline
Staying with stock
  #63
Old 01-18-2017, 07:46 PM
footjoy's Avatar
I pulled ahead off and its got the dreaded 8VR pistons bored .040.
Its not a race car
  #64
Old 01-18-2017, 08:14 PM
footjoy's Avatar
when doing compression calculator is the 8VR considered a straight flat top no dish?
  #65
Old 01-18-2017, 11:09 PM
FrankieT/A's Avatar
I believe the intake valve on those heads is 2.11" already, if that's the case it would certainly be worth putting in the 1.77" exhaust. You would end up with a killer set of heads. And of course, now is the time to do it. JMHO
  #66
Old 01-19-2017, 08:05 AM
FrankieT/A, The 1970 #15's are the small valve 85 - 90 cc chamber head on the 360hp 455's standard in Bonneville's and optional in other B-bodies, not to be confused with the optional 370 hp 455HO (360 hp in the A-bodies and GP) with the large valve #64 heads.
Dennis
  #67
Old 01-19-2017, 08:58 AM
Greg, I believe that the std. 4 vr pistons (flat top) are rated at 6 cc volume. The 8 vr piston is more like 10 cc. Does the perimeter also have the bevel cut? I also heard the pin height on these were changed to drop them a little lower in the bore to account for some deck planning. You'll have to measure the deck height to know for sure. Post a picture of one of the pistons at TDC.
Dennis
  #68
Old 01-19-2017, 09:44 AM
footjoy's Avatar
Dennis
So for clarification if it s 10cc with 87 cc chamber does that make it 77cc or 97cc chamber.
thanks Greg
  #69
Old 01-19-2017, 01:04 PM
thanks Greg
Greg, did you try using the Wallace Racing calculator?
Dennis
  #70
Old 01-19-2017, 01:32 PM
Just playing around on the Wallace Racing compression calculator, I got 8.77:1 using 87cc chambers, 10cc vr, .030 head gasket, 4.30" gasket dia., .015 deck for your .040 over 400 (408). It would be 9.18:1 with '0' deck pistons, all else the same.
Dennis
  #71
Old 01-19-2017, 08:06 PM
footjoy's Avatar
Dennis
I plan on running 91 octane.
On another subject how come pontiac head gaskets are so expensive?
Thanks Greg
  #72
Old 01-19-2017, 10:24 PM
FrankieT/A's Avatar
Dennis
Dennis,
Not confused at all, I just couldn't remember if they had the big intake and small exhaust or both small valves. The 15 head is great head to convert to high performance for a 455 yielding 10:1 being 64's availability and cost being what it is. I wouldn't put 15's on a 400 though, the compression would be too low for my taste. But that's me. That's why they make chocolate and vanilla. If you look through the thread you will notice I was the first one to suggest a head swap. I'm a firm believer that acceleration is directly proportional to compression.
  #73
Old 01-20-2017, 08:04 AM
FrankieT/A, Sorry I didn't mean you were confused, just clarifying the differences between the '70 455 heads. Another seldom seen '70 head is the #16 small valve high compression (10.0:1 advertised) head used on the 290hp (2-bbl) and the 330hp (4-bbl) 400's. The 290hp was only in the B-bodies while the 330hp 400 was both A (non-GTO) & B body installations. It has a 78 cc chamber.
Greg, My brother used the dreaded 8vr pistons (+ .030) in a simple rebuild to a '73 400 4-bbl in a Bonneville a few years ago. He measured the vr's and they were 14.5 cc's! He couldn't recall if they had the bevel around the piston crown or not. He calculated the compression to be 7.5-ish, but the car ran strong and was peppy. So that would bring your compression down almost a half point.
Dennis
  #74
Old 01-20-2017, 09:34 AM
footjoy's Avatar
Dennis
So if it is 7.5 what will I do with this K2801 cam that I just got. It says 9.0 compression.
  #75
Old 01-20-2017, 09:59 AM
Greg, No, my brothers 400 had 7.5 compression. You'll be in the mid-8's with those 8-vr pistons. Did you check to see what deck height you have to determine the head gaskets you need to buy? I have a new Summit 2800 cam & lifter kit I'll trade you for if you need too.
Dennis
  #76
Old 01-20-2017, 10:02 AM
BTW, I have the 2801 in my stock 455HO (actual 8.4:1 compression) motor and it is sooo mild. Let's see where your actual static compression is to select to best cam.
Dennis
  #77
Old 02-17-2017, 01:18 PM
JC455 JC455 is offline
I am looking for some Ferrera 1.96 valves I have not located any. Where can I buy some.
Thanks Greg
If not too late, you can always upsize to a Chevy 2.02 valve. Have your machinist compare specs vs. the 1.96 valve.
John
IG: @crawdaddycustoms
YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos
  #78
Old 02-22-2017, 12:11 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
If you are up for the cam swap the heads are easy to change then. Any good local deal cheap on a small valve head from 68-78 off a 350 would range from 78-80 cc 68-70 , up to 93 cc 71-78 and still get you at least in the 8+ :1 range closer to 9:1 it would make the difference and run well with the 2801. Just lose the 98-101 cc chamber 400 heads save em for a 455. Years back I did a 2801 on 400 that had crap pistons in a 76 TA for my brother in law, but swapped to 1970 #11 heads rated 8.8:1 I think. So it might have been 8.2 actual and it only had single exhaust but that THING RAN REAL WELL for what it was
63 Catalina coupe 455 budget drag car 11's 1/4 , 7.4 1/8th
66 Star Chief Executive 57k mile
69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2007 Hummer H3 3.7 liter turd
2019 Chevy Spark petrol car 38 mpg
  #79
Old 02-22-2017, 08:29 PM
Good points Larry. The #15 heads Greg has actually measured at 87 cc's, so his compression is in the high 8's on a .030 over 400. I think the 2801 cam is a good choice for his combination.
Dennis
