Old 10-02-2017, 07:43 PM
tstroud tstroud is offline
The manifolds arrived today. They look pretty good but there are definitely some very sharp edges that need addressed. A few minutes with the die grinder and they will be really nice.
What are people using for a coating on these?
These headpipes have some bends in them that I didn't see in the Pypes headpipes. I will have to compare them more closely since i have both here now.
  #42
Old 10-02-2017, 08:32 PM
Formulajones's Avatar
The cheapest and easiest coating would be the POR15 grey manifold paint. I just brush it on right out of the can. Stuff is tough as nails. I've had it on one of the cars for 2 years now daily driving it and it still looks like the day I applied it.
  #43
Old 10-02-2017, 08:55 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
This is what I used and have 2 other times. I put VHT High temp primer under it and then grill it at 300 for 30 minutes.
  #44
Old 10-02-2017, 09:42 PM
I put mine in the oven, don't ever do that
I spent the rest of the day with windows open and the fans on trying to air out the house before my wife got home.
  #45
Old 10-02-2017, 10:38 PM
There was some really sharp machining burrs on the manifolds but it didn't take long with a die grinder and a carbide burr to smooth things up. They are really nice now. Not really a big deal considering the price.
I can get some POR 15 manifold paint in the next town over tomorrow.
  #46
Old 10-03-2017, 10:30 AM
I hope the grey works better than the aluminum high temp paint from POR15.
I used the aluminum twice on some SBC exhaust manifolds. I sandblasted them and washed them with the prep spray before painting and they still burnt off after just a couple drives.
To be fair, I did not bake them in an oven. I cured them on the vehicle so it may not have worked so well.
  #47
Old 10-03-2017, 06:00 PM
ponchjoe's Avatar
Don't forget Por 15 primer or another very high temp primer like VHT
  #48
Old 10-03-2017, 06:49 PM
Next question.
What are you using for gaskets since these come with none.
  #49
Old 10-03-2017, 07:01 PM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
Originally Posted by tstroud View Post
Next question.
I plan on using factory style metal gaskets. That's what I used on my dad's 66 about 15 years ago.
Old 10-03-2017, 09:40 PM
The factory style gaskets that came in my Fel Pro kit do not have a divided center ports. Do some of the stamped steel gaskets have divided center ports?
  #51
Old 10-04-2017, 09:42 AM
Mr. Gasket I believe has the divider in their copper gaskets.
Old 10-04-2017, 01:19 PM
ponchjoe's Avatar
I've used the factory gaskets on all 3 sets I've installed. A little high temp to aid in sealing doesn't hurt either.
  #53
Old 10-04-2017, 05:00 PM
Well, If it's not a problem that's what I will do too.
  #54
Old 10-05-2017, 01:26 PM
My manifold kit arrived yesterday ! All looks good.
Old 10-05-2017, 07:38 PM
ponchjoe's Avatar
BTW, I never did receive anything back on my question about the lack of finish work on these castings. Mine are now installed so it's all good.
  #56
Old 10-05-2017, 08:24 PM
Riderfan Riderfan is offline
Never saw the original listing. What was the price when they had stock?
  #57
Old 10-05-2017, 09:12 PM
ponchjoe's Avatar
$379 for uncoated 2.5 OS manifolds, down pipes and all bolts shipped.
  #58
Old 10-05-2017, 09:19 PM
Thanks!
But 'may not ship to Canada'. Meh, I'm sure they will, just not for free. Should still a good deal though.
  #59
Old 10-05-2017, 09:49 PM
Functionality, mine were fine right out of the box. They just needed a bunch of sharp edges touched up. I don't like sharp edges. It is a good deal if you can get it.
Sent from my iPad using Tapatalk Pro
