Old 10-01-2019, 12:54 PM
Apache Warrior's Avatar
Apache Warrior Apache Warrior is offline
Default 1963 LeMans For Sale - Chicagoland Area
***Being Sold As Is – Roller Only – No Motor or Transmission***
No Trades
$13,500 Firm
1963 LeMans Sports Coupe
Body Plate Reads as Follows:
Style 63-2217
Trim 217
2C-4B-4G-4R
3250 lbs w/ Driver (Weighed at Norwalk)
All Steel Except for Hood Scoop
Yorktown Blue Poly Original Paint (From What I Gather)
Chromoly 8pt Cage w/Halo – Tig Welded and Professionally Built/Installed
Strange Engineering Dana S60 Rear Housing w/ 4.56 Pro Race Gears & Spool
Strange Engineering 35 Spline Axles w/ 5/8” Wheel Studs
Competition Engineering Ladder Bar Suspension
QA1 Coil over Shocks
Wilwood Disc Brakes Front & Rear
Wilwood Master Cylinder
Mark Williams 3.5” Chromoly Driveshaft 44 7/16” length 10,000 RPM Max Critical Speed
Hurst Line-Loc
Lokar Adjustable Gas Pedal – Original Mechanical Linkage Included
Weld Racing Pro-Star 96 Series Wheels 15x4 Front
Weld Racing Pro-Star 96 Series Wheels 15x10 Rear 3.5”BS
Mickey Thompson ET Front 26x4.5x15 Tires
Mickey Thompson ET Street Bias Ply 28x11.5 Tires (No Tubes Installed)
BOP Engineering Front Motor Plate Customized For Vehicle
Engine Cradle Crossmember Modified for Additional Clearance to Run Engine Diaper w/Tow Hook Attachment
Steering Rod Has Been Modified to Remove for Extra Header Installation Clearance
RCI 10gal Fuel Cell Modified for 1/2NPT Outlet Fittings
Fuel Cell Custom Mount Included
All Moldings Included
Extra Windshield Moldings and Window Side Moldings and Rear Window Trim (Lower) Included
Set Up for Clutch Assisted Transmission (Modified Trans Tunnel)
Custom Clutch Heavy Duty Z-Bar and Clutch Actuating Rod
Lightweight Modified Trans Crossmember
Hooker 2” Headers Modified for Vehicle
3.5” Exhaust Included (Exhaust Exits Just Behind Driver & Passenger Seating Locations)
Hood Has VFN Extra Large Super Duty Scoop
New Windshield and Weatherstrip/Seal Professionally Installed
Original Seats Included
Extra Set of Racing Seats (Plastic/Polymer) Included
I Do Not Have PHS Documentation
VIN 263P100915
Can Help Deliver to Chicagoland Area Up To 100 Miles On a Weekend Day
Located in Wauconda IL – Zip Code 60084
PM Me If Interested and Include Your Phone Number and Name and I Will Contact You
ID:	521307   Click image for larger version
ID:	521308   Click image for larger version
ID:	521309   Click image for larger version
Old 10-01-2019, 08:11 PM
wts69bird wts69bird is offline
Does it have a title? Do you have the grills?
Old 10-01-2019, 09:40 PM
Title - Yes
Grills - Yes, they are currently installed.
No fuel system currently in the car other than the fuel cell.
Old 10-04-2019, 09:36 PM
Mike Davis's Avatar
Has the Chassis ever been certified?
How fast has the car run?
Could you post some more pic, interior and engine comp?
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 10-07-2019, 08:33 PM
Mike Davis's Avatar
PM Sent
Old 10-15-2019, 02:28 PM
Originally Posted by Mike Davis View Post
PM Sent
Have been traveling so slow to reply, my apologies. I will be home this weekend and will try to take new pictures of the engine bay, underside, trunk area, interior.
Chassis is not certified.
I actually made a typo as this is truly a 6pt chromoly cage with a halo added. No dash bar.
Radiator is not included.
Roller means no motor or transmission.
Car went 11.70's at Norwalk with a mild 474 and Jerico. These were first and only runs with a solid cam and 300cfm Edelbrock heads and single 4BBL.
Old 10-15-2019, 09:44 PM
Mike Davis's Avatar
Thanks, looking forward to seeing more pics.
Old 05-14-2020, 10:36 AM
TAn2BIRDS's Avatar
TAn2BIRDS TAn2BIRDS is offline
Is this for still for sale PM sent
Old 05-20-2020, 07:46 AM
Mike Davis's Avatar
I never heard back from him. I don't think he is on here much.
Old 09-03-2020, 12:10 PM
Bump.
More pics to come.
Old 09-11-2020, 02:28 PM
Sale pending.
Old 09-11-2020, 09:08 PM
pontiac rodder's Avatar
pontiac rodder pontiac rodder is offline
Congrats to KK for getting it back
Old 09-16-2020, 04:29 PM
kking's Avatar
kking kking is offline
Thumbs up
1963 Tempest
1969 Pro Touring GTO All Aluminum 505 IA, 4L80, Roadster Shop Chassis
2004 GRAND AM TUBE CHASSIS RACE CAR 505 IA II 7.92@173
