curious ; 462 in a 70's GMC ? Any one completed one ?
I'm curious about the possibility of installing a 462 in a truck ? I have a 462 going to dyno it next week and I would like to have a pick up . I don't have anything to put it in as of yet . JUST THINKING !!!
It can certainly be done. Starter is on the wrong side vs chevy, use a bop to chevy trans adapter. Usually just use the engine mount off the frame of a car to go and set the engine down into the chassis with the motor mounts on. I even know 2 guys that have put 455 pontiacs in 70s 4x4 FORD pickups, one has ram air manifolds and the new process 4 speed from the ford 300 6 behind the 450 hp 455.
This thread had some good details for a swap for a 2wd. http://forums.maxperformanceinc.com/...d.php?t=596830 Last edited by Jay S; 10-14-2019 at 11:16 PM. Reason: Edit |
I installed a 455 Pontiac in a 1963 Chevy 1/2 ton 2wd. If you use the correct parts it's a bolt in. Removed 6 cyl. mounts. Used the U-shaped steel Pontiac upper motor mounts from a 1970's Pontiac and the Z-shaped steel piece from a mid 1970's Chevy/GMC 2wd pickup that runs from the top of the frame to the front cross member. I also used the rubber lower mount that was already on the Chevy Steel piece. It fits the Pontiac upper u-shaped mount. Everything that I used was bolted in the two vehicles so no cutting or welding is required. Bolt everything to your Pontiac engine and lower it into the frame of the truck. Mark the frame rails and the cross member where the Z-shaped pieces sit and drill new mounting holes. I used a BOP Turbo 400 and everything cleared. You will have to move/change trans cross member. Good luck. If truck has PS use the pump and brackets from your engine. Stock exhaust manifolds fit fine. I don't know about headers.
we put a 400 Pontiac into a 58 chevy 2wd truck in the 70's... seems it went in pretty easily as I remember. Ran like a beast..
1967 GTO, 467 roller motor, e heads ported, tremec T56 magnum 6 speed and 9" done. EZ EFI 2.0 with FAST dual sync distributor and separate nitrous system done. Track is at 4300 ft elevation. so far a best of 11.95@116. Suspension now getting dialed in...tubular front a arms with dual adjustable coil overs HR Parts n stuff rear bar and whole car lowered 3 inches.. |
Swap candidate right here: https://forums.maxperformanceinc.com...d.php?t=817991
I have a friend who swapped well-built 462 into a ‘69 Chevy 3/4 ton long bed pickup, it was a nice fit and man did that truck ever move out.
My sister has a 455 in a ‘70 GMC and our dad is currently building a 428 to put in his ‘68 GMC. No real problem for either one. I posted these pics before. Not sure it ever got done by the factory though.
1999 WS6 Formula, 1 of 175 1967 GTO Linden Green 4 spd, A/C, survivor 1967 Lemans convt 1967 Firebird 400 bench seat, deluxe interior, auto 1965 GTO 462, KRE unported D-port heads, Bullet 234/244 cam, th400, tight 10" converter, 3.73 gears, 87 octane, 3440 lbs. empty,1.59 60ft, 7.159@95.33 (1/8), a real daily driver, been totaled, rolled 3 times, hit a tree airborne. 1961 Catalina 2 door htp 1960 Ventura 4 door htp wife's car 1960 B'ville 2 door htp 1960 Catalina Wagon wife's car too Last edited by Ducks Goat; 10-15-2019 at 01:41 AM. |
Assembly manual
1999 WS6 Formula, 1 of 175 1967 GTO Linden Green 4 spd, A/C, survivor 1967 Lemans convt 1967 Firebird 400 bench seat, deluxe interior, auto 1965 GTO 462, KRE unported D-port heads, Bullet 234/244 cam, th400, tight 10" converter, 3.73 gears, 87 octane, 3440 lbs. empty,1.59 60ft, 7.159@95.33 (1/8), a real daily driver, been totaled, rolled 3 times, hit a tree airborne. 1961 Catalina 2 door htp 1960 Ventura 4 door htp wife's car 1960 B'ville 2 door htp 1960 Catalina Wagon wife's car too |
K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
I installed a 71 400 in my 74 2500 2 wd truck back in 80. Used frame mounts redrilled frame. Used longer battery cables,stock oil filter. Stock log manifolds, qjet,long tailshaft 65 turbo hydro with convertor out of 65 Cat. Cut driveshaft.used stock column shifter,needed adjusting as I couldnt manually get low. I dont remember radiator fan and hoses.Worked fine for my work truck everyday leaving in drive.World of difference hauling torque.
Thanks for all the info and please keep the info and any pics coming !!
