Old 10-14-2019, 08:55 AM
Jim Moshier's Avatar
Default 7C3 heads
I was looking thru some heads last week and came across some 7C3 heads from what I can figure out a 1973 400. Has anyone heard of these and any history, back story. Thanks in advance.
Jim
ID:	522115   Click image for larger version
ID:	522116   Click image for larger version
Jim Moshier
1962 Catalina 389
Old 10-14-2019, 09:10 AM
They where a strange Head as where many from late 72 - 73 other then the 455SD head.
Fior some dam reason Pontiac reverted back Exh port wise to there first V8 heads in the mid 50's where the center Exh port divider from the head bolt on out to the flange is missing/ not cast into the Head, which sucks for Exh flow!
In short they make for them being a grocery getter Head, or a good door stop or paper weight!
Old 10-14-2019, 11:20 AM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
Definitely very early 1972 heads for 400 4bbl applications. They were superseded by 7K3 early in the model year.
Do you happen to know the date codes on them?
Old 10-14-2019, 12:38 PM
Thanks guys, yes very weird looking with no divider on the middle ports and would agree it would hurt exhaust flow as would the 3 tube header design.
Rocky no, I don’t have the date from the heads sorry.
Jim Moshier
1962 Catalina 389
Old 10-14-2019, 02:54 PM
77 TRASHCAN's Avatar
Best use would be for trade in cores....
Shut it off
Shut it off
Old 10-14-2019, 03:02 PM
I don't own these heads, as I just saw them for sale and they are asking $500 for the pair I think, The ad says a rare find....... I just thought I would inquire as I have never seen these heads before.
Jim Moshier
1962 Catalina 389
Old 10-14-2019, 03:08 PM
Thanks, Jim.
I'm not sure they're worth $500, but they're definitely more usable than cores. They're essentially 7K3's.
Old 10-15-2019, 06:18 PM
I wonder how the old timey exhaust port was allowed to be used in the early 70's?
I wonder if someone in charge at PMD got nagged to death by some old geezer engineer on the staff, about how well those old heads performed, exhaust wise...and let that design to be used on the 7C3's???
Shut it off
Shut it off
Old 10-16-2019, 06:18 AM
In the mid 50s the engineer's did not really know better in terms of Exh flow , in the early 70s I think the corporate bean counters just wanted to save on the cost of cast iron until the engineers steeped back in and said screw you where loosing performance and possibly sales!
Old 10-21-2019, 06:19 AM
Well I unearthed my notes on the 72 head castings and I have this info to relay.
The early 1972 heads which by date code would have started to be cast in mid to late August of 71 and had Head codes of 7A1 thru 7E5 and they all where open center Exh configuration.
The 7E5 casting was the standard 455 casting and if I recall right was a pressed in rocker stud version.
The late 72 castings of 7H1 thru 7M5 reverted back to the normal seperation of the center Exh ports.
Unfortunately I have no notes as to what month in 72 that factory started casting heads the right way if you will!
Old 10-21-2019, 10:13 AM
thanks Steve.
Jim Moshier
1962 Catalina 389
