If/when you have more info, lemme know.
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
My 7F6 heads are dated A052 and do not have the scallop.
Anyone else?
G011 with the scallops. Will also be going back on just as they are.
I'll get the date code from my 72 tomorrow, they have the scallops that much I know..
Mine are on a Formula, not a GTO, but anyway.. Just took a look, and it looks like I241 or 1241.. or I am looking in the wrong place. Just under he valve cover rail just ahead of the right hand ex port, right? They were cast on night shift if that makes a difference to anyone..
And, thanks.
By the way, mine are AO52 without the scallops.
See what you started?
hi.just got mine dug out.A052 no scallops.intake is 12 20 71 just for your info.next time i get to the block i'll get the dates off of it.this motor was bought separate from a car,i know it's a YE but thats all.
FREEDOM ISN'T FREE BUT WORTH FIGHTING FOR |
C142 no scallops. Restored them 30 years ago. Still sittin on the shelf.
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
Thanks, ogr, added your pair to my list.
Lloyd,
I have a 9D 72 T/A. I will check the heads and get you the codes for your database. JOhn |
Lloyd,
Checked them out ...J011, both of them. Do not have the scallops. The PO had the motor apart..did the SD internals(still on my stand) and might have messed with the heads, but... I know about decking to true the heads but would he have been able to have the intake side milled ? The mating surfaces of the head/head and head/intake don't look like they have been cut. He scribed the one head in an attempt to start what I am guessing was a gasket match to the intake and then the work stopped. The other head looks like it hasn't been fiddled with but who knows. The motor work was supposed to have been done by a Pontiac shop in the Jacksonville, Fl area? Last edited by tajohn; 10-21-2010 at 06:19 PM. Reason: spelling |
The set for my Sundance car - I171 & I241, have the notches (scallops).
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
#38
Yours are the very first 1971 dated 7F6 heads I've heard of without the scallops. I'm betting that they've been surfaced on the intake side . . .
#39
Thanks, Chris. Added those to my list.
#40
I don't think its possible to resurface the intake side of those scalloped heads enough to remove the scallops. You're talking about almost a 1/2 inch, total depth for the two cylinder heads. There wouldn't be any way to get the intake to fit at that point.
