Old 02-17-2019, 06:05 PM
racerboy's Avatar
racerboy racerboy is offline
Default Power steering box
I've slowly been collecting parts to covert my manual steering over to power steering for the '70 Judge. I'm trying to make it look as original as possible. I think I have all of the parts except the steering box (and p/s pump). I'm ok with going with a faster-ratio box, but want it to resemble the OEM box. Any recommendations? Are the ones that AMES sells any good? Of course I have no core to send, so I'm guessing I am going to pay a premium.
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
Old 02-17-2019, 11:08 PM
abefromen's Avatar
abefromen abefromen is offline
https://www.ebay.com/itm/QUICK-RATIO...53.m1438.l2649
Old 02-26-2019, 05:04 PM
racerboy's Avatar
Originally Posted by abefromen View Post
I ordered the box from that vendor. Real nice guy. Box should get here this week.
As far as pulleys go, I think I am going to go with a set of reproduction ones. I see that Ames has the water pump, crank and p/s pulley for about $200. OPGI has them as well, but that set runs about $283. I would think that they are coming from the same supplier, and are both stamped with he correct part numbers. I do see that OPGI calls them 'Authentic Reproductions'. Is there any difference? I prefer to go with Ames, since they sponsor this forum, unless the other vendors offer higher quality pieces.
Old 02-28-2019, 02:19 PM
racerboy's Avatar
Anyone have any experience with the repro pulleys?
Old 02-28-2019, 02:42 PM
Scott Thelander's Avatar
darn....
I have a sweet 3 1/4 turn k-69 steering box
to go with the complete 70 power steering pump n brackets tooooooooo
Scott
Old 03-02-2019, 12:25 PM
Kennybill Kennybill is offline
https://www.speedwaymotors.com/Lares...rs,372171.html
Old 06-15-2019, 05:23 PM
racerboy's Avatar
So I’m knee deep in my manual to power steering conversion. I got the pitman arm off of the manual steering box, but how do I get the small end off the idler arm (or whatever it’s called that it attaches to)?
Old 06-15-2019, 07:08 PM
racerboy's Avatar
Figured it out.
Old 06-15-2019, 07:11 PM
racerboy's Avatar
Manual steering box
Power steering box
Does anyone know what I’m supposed to torque the pitman arm too?
Also, is my + battery cable supposed to just lay on top like that? On my ‘67 HO car, it runs through a little tube that bolts to the engine mount. This one does not. It just kind of hand there.
Old 06-15-2019, 08:00 PM
OG68 OG68 is offline
]Factory manual shows the cable going under the steering gear. Drawing is not the best quality.
2007 Cadillac SRX
Old 06-15-2019, 08:48 PM
racerboy's Avatar
Thanks!
Old 06-16-2019, 01:11 PM
racerboy's Avatar
So the new double-groove water pump pulley is about an inch taller than the single groove one. That is going to push my fan an inch deeper into the shroud. Is that bad?
Also, I haven’t had any issues with overheating but had a couple of questions.
1. Is this the correct fan for my car? No clutch, just a 5-blade ‘flex’?
2. Is there a way to ensure that my Rallye Gauge is showing the correct temperature? I had a shop try and fix my fuel gauge a couple of years back and they didn’t do it right. They replaced the gauge (not sending unit) but now the needle only starts to move when I’m at about 1/2 tank. Since they butchered that, I’m curious about verifying that my water temp (as oil pressure) gauges are correct.
Old 06-16-2019, 01:40 PM
Hi
your fan remains in the same spot
the pulley is stacked/added towards the motor... say on the rear of your manual pulley for water pump
the water pump s fan hub hasnt moved
so the fan wont move
you have the right idea
flip the w/pump pulleys face down.....
thats the image your looking for...
all is good
continue on
now the crank pulley stacks the 2nd pulley to the front 4 power steering
great fans ,,,, it should use a 2.5?" spacer .... also there is a date on the rear side on the riveted blade clamp reinforcement
bracket arm it may even be stamped on a few of them arms
Old 06-16-2019, 04:20 PM
racerboy's Avatar
Thanks Scott
I tried bleeding all the air out of the system as follows:
I filled reservoir, jacked up front end and turned lock to lock a bunch of times, adding fluid as I went.
Lowered car, started it up and went look to lock 2-3 times. Checked fluid, added, repeat. Finally was in a good point for test drive. Aside from the steering wheel being way off, it feels stiff. It doesn’t spin freely all the way. It almost feels like it gets hard to turn in middle then easy again. Did I do something wrong ?
Old 06-16-2019, 04:28 PM
racerboy's Avatar
Feels ‘notchy’ if that makes any sense
Old 06-16-2019, 04:50 PM
racerboy's Avatar
Wheel going straight. Can I just pop this off and correct it?
Old 06-16-2019, 05:34 PM
racerboy's Avatar
So I learn things the hard way.
I just broke the little stalk for my horn switch. My horns have never worked (that was on this Summers’ list).
What is the little wheel thing with the push button?
And do I have to adjust my steering coupler to get my wheel straight. If I just reinstall the wheel, the home in the steering wheel won’t align with the (broken) stalk.
Old 06-16-2019, 05:54 PM
racerboy's Avatar
Is the pitman arm in correct position? This is with the wheels ‘straight’ but the steering wheel cock-eyed. If this is correct, do I have to adjust the steering coupler to get wheel straight?
Old 06-16-2019, 05:55 PM
racerboy's Avatar
Pitman arm
Old 06-16-2019, 05:58 PM
racerboy's Avatar
I just remembered that the coupler only goes on one way, because there is a flat spot where it slides over steering box gear. So now I’m really confused
