Old 03-10-2019, 01:27 PM
bulletpruf's Avatar
bulletpruf bulletpruf is offline
Default 4 Bolt 400
Fellas
Long time no see.
Buddy has a 4 bolt 400 block. Said to come out of a 69 Judge. Don’t have codes yet just saw pic of bottom end.
I can’t remember - did any RA III come with 4 bolt mains? Or only IV?
Scott
Please check out my YouTube channel for vintage/classic car and truck builds and shenanigans! https://www.youtube.com/watch?v=jq61KxKp1Is&t=14s
Old 03-10-2019, 01:29 PM
factory '69 usage RAIII blocks were 2bolt mains.
Old 03-10-2019, 01:36 PM
tom s tom s is online now
70 RA IIIs were 4 bolt caps along with RA IVs.Tom
Old 03-10-2019, 03:35 PM
Joe's Garage Joe's Garage is offline
Default You may find that it is a Service Replacement block
All of the Service Replacement (SR) 400cid blocks we've handled had 4-bolt mains, although I believe they were produced both ways.
I think Pontiac figured that if you managed to break a 2-bolt block, replacing it with a 4-bolt block might be a good idea.
As Tom S points out, ALL the factory 1970 Ram Air III and IV engines had 4-bolts. In 1969 it was only the RAIVs.
But Pontiac was always nice enough to produce something that challenges any absolutes we thought were undeniable.....
Old 03-10-2019, 03:57 PM
bulletpruf's Avatar
Thanks fellas. I’ll post the #’s when I get them.
Old 03-10-2019, 06:09 PM
napster's Avatar
napster napster is offline
Bulletpruf,
Welcome back. Look forward to your future posts. Always interesting and educational.
BTW, thanks for your service.
Jim
Old 03-10-2019, 09:26 PM
bulletpruf's Avatar
Originally Posted by napster View Post
Bulletpruf,
Jim
Thanks, Jim. I appreciate it.
Scott
Old 03-11-2019, 02:45 PM
HUMBLER's Avatar
HUMBLER HUMBLER is offline
Numbers yet? ;-)
1969 Judge (Liberty Blue / Blue, 4SPD)
Old 03-11-2019, 07:00 PM
Brewster's Avatar
Brewster Brewster is offline
Right, I guess Im not the only one looking for their correct lost 1969 RAIII motor.
Oh please, Oh please, Oh please be mine
Humbler, are you the Craiglist searcher?
Old 03-11-2019, 07:26 PM
bulletpruf's Avatar
Guy was told that it came out of a 69 Judge. If so, perhaps it's a IV block. We'll see.
Old 03-11-2019, 08:05 PM
Douglas Willinger's Avatar
Douglas Willinger Douglas Willinger is offline
Some 1970 model year Ram Air III engines have the 9799915 block (9799914 with the 4 machined away and replaced with a 5), with the WS (manual) stamp on the front.
My February 1970 Lordstown produced 4 speed M-21, blue/blue deluxe interior TA that I have owned since 1979 has that, with the W well stamped but the S more faintly stamped. Block's casting date is early January.
1970 Lucerne Blue Firebird Trans Am, deluxe blue interior. Original Ram Air III, M-21, 3.73. Being built as a 4" stroke "434" with SR 614 Ram Air IV heads
1972+ Lucerne Blue 4-door hardtop "what if" T-41 Le Mans Sport GT/Grand Am concepts. Equipped with future 3" journal "455 HO"/"what if" prototype "SD 455".
What if GM had continued production of the 1970-72 GM A body somewhere in the southern hemisphere?
Old 03-11-2019, 10:33 PM
Lordstown produced 70 Ta ?
Old 03-12-2019, 07:29 AM
He probably sees the 'L' figuring it's Lordstown?
(L is for Van Nuys )
Old 03-12-2019, 05:54 PM
I stand corrected.
Was going from memory.
My 1970 Trans Am has the "N" - Norwood, Ohio.
https://www.hotrod.com/articles/norw...plant-reunion/
https://www.chevy-wiki.com/wiki/Norwood_Assembly
Yes, "L" is Van Nuys.
Question- how did they get an "L' designation, rather than say "V".
Old 03-27-2019, 04:00 PM
I believe the L for Van Nuys signified Los Angels but just a guess.
Factory literature indicates even the base GTO 400 with manual trans (WT) was four bolt main. I don't know if this was actually the case in production.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 03-27-2019, 05:03 PM
Default We've had a couple 1969 'WT' engines and four or five 1970 'WT" engines.
Every one of them had 2-bolt main caps.
And ALL of the 1970s were drilled for 4-bolt mains, but had 2-bolt caps. The 1969s did not have the extra holes drilled.
But you never know what Pontiac might have done.......
Old 03-27-2019, 05:20 PM
btw in my last post I forgot to say i was referring to the 70 model year, 69 was all 2 bolt except the RAIV but factory literature for 1970 model year says all GTO' engines except the base 400 with automatic (YS) had 4 bolt mains. Has anyone seen 1970 WT (350 horse 400 with manual trans) with 4 bolt mains?
1969 Bonnie Cvt
Old 03-27-2019, 05:50 PM
66beaumont's Avatar
66beaumont 66beaumont is offline
I have original YS block in my 69 and it is drilled for 4 bolt mains
69 gto ,all#match,467,th400,3:55 Easton posi,resto completed may 2016. 427 hp/530tq. Stump puller with stock#62 , stock intake and qjet
Th400 gone. Tkx close ratio with .64 of
66 Pontiac Beaumont sport deluxe,BB 5sp tko 3:08 auburn 450hp 550 torque wife sold it
Old 03-27-2019, 06:12 PM
unruhjonny's Avatar
... Has anyone seen 1970 WT (350 horse 400 with manual trans) with 4 bolt mains?
Members here have posted in the past first hand accounts of seeing 4-bolt 1970-WT engines;
From what I've understood, it wasn't the norm, but wasn't terribly unusual either.
From everything I have read suggests that pre-1970 400 blocks all had two bolt mains except for the RAI, RAII, & RAIV;
It reads as though starting in 1970 things changed a bit, as all the RAIII engines came with four bolt mains, and up through 1972 the odd 400 Firebird/GTO manual transmission engine has been found to have four bolt caps.
It also reads as though starting in 1970 (maybe this also applied to late 1969 blocks as well) all 400-4bbl engines were drilled and tapped for four bolt mains.
I am unsure as to when 400 blocks started to usually NOT be drilled and tapped for four bolt mains - although I'd wager a guess of 1973
Regarding the earlier comment:
I have not read this;
It reads as though the block was replaced with either an as correct one, or a readily available one.
HERE is the thread I recently created asking about SR blocks.
1970 Formula 400
Old 03-27-2019, 08:22 PM
muscle_collector's Avatar
if you go to the other thread this has been discussed recently and I posted pics of 2 69 WS blocks that were drilled for 4 bolt but with 2 bolt caps. I have had several WT code 69 engines that were the same way drilled for 4 bolt but with 2 bolt caps.
