Old 09-09-2019, 08:12 PM
JLMounce JLMounce is offline
With the camaro style splitter installed the baffle doesn’t do anything aero-wise for you. The splitter is creating a low pressure area behind it, before the baffled which is designed to creat a low pressure area behind it. What it does do however is keep that low pressure area from pulling cool air out of the front end where it needs to be to flow across the radiator.
In short, even with a splitter in front of it, you still want it in place.
-Jason
1969 Pontiac Firebird
Old 09-11-2019, 02:13 PM
grivera's Avatar
grivera grivera is online now
So I installed it on Saturday. I located the inner fender hoes - they just needed some coercing. Overall, I like the piece and I didn’t have to drill any new holes.
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 09-11-2019, 02:18 PM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
Any improvement in cooling?
Karl
Old 09-11-2019, 02:20 PM
92GTA's Avatar
92GTA 92GTA is offline
Nice, I just ordered mine yesterday.
Old 09-11-2019, 02:50 PM
grivera's Avatar
Mine already cooled pretty well and in my short drive after installing it I didn't really notice a difference. I hope to evaluate further this upcoming weekend.
Will Rivera
Old 09-11-2019, 05:53 PM
cnc's Avatar
cnc cnc is offline
Looks good Will
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 09-13-2019, 02:31 PM
Firebob's Avatar
Firebob Firebob is offline
Did you buy the eBay one you first linked to?
Robert
69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always )
http://youtu.be/eaWBd3M9MN4
Old 09-13-2019, 02:42 PM
92GTA's Avatar
That's where I got mine. The metal ones are way to expensive when I'm not doing a stock restoration.
Old 09-13-2019, 03:34 PM
My 69 TA was missing the baffle (and the air dam that bolts to it of course). I ordered an original steel nice used one on eBay and it bolted in with no issues. I wonder what the factory application of these baffles were? I think all 400's had them as well as all 350 (2 or 4bbl) cars with AC.
My Sprint had the upper baffles but not a lower one. The car is virgin enough that it clearly never had the lower baffle and the upper baffles had the identical patina and correct hardware so I'm sure they were factory also.
Has anyone else seen a factory install of the upper baffles but not the lower?
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 09-13-2019, 07:09 PM
I just looked it up in the MPC (nov 69)
Lower baffle is actually called (Baffle, front panel to sheet metal) and it lists it for 6cyl with AC and all V8. Pn. 9796251
Interestingly there is another number for the baffle for Ram Air cars (9798498). It is almost 4 times the price and I suspect they meant to say The Trans Am, it probably included the air dam.
I also looked up the upper baffles (officially called: Filler, cross brace). Pn is 9794808-9 for RH &LH).
It shows application as being all AC and all 400.
My experience is that cooling baffles, shrouds etc always had murky application rules. I suspect the application criteria changed during the model year as additional testing altered the need for their use.
1969 Bonnie Cvt
Old 09-28-2019, 07:32 PM
grivera's Avatar
Yes- PartsPlace
Will Rivera
Old 10-05-2019, 06:43 PM
92GTA's Avatar
So I've had the plastic PP version installed for a few weeks. Had to do 4 small trims to make it work with my spoilersbyrandy front lower air damn but it fits great.
It has made such a tremendous difference in cooling going down the highway I felt compelled to revisit this thread to post about it. I can't say that it does anything in city traffic, but WOW what an improvement in highway! Soon as I get on the highway now the temp cools down faster than ever. This is a must for anyway who drives in a warmer climate of has more than a stock engine which could use extra cooling.
Old 02-29-2020, 08:24 PM
DM3 DM3 is offline
So I test fitted the valance baffle on my 67 about 15 times grinding little by little until I was happy with the fitment. Then put several coats of paint so my boys and I could install this weekend. I also fitted the aluminum air baffle and/or front spoiler onto the valance baffle and drilled all the holes after triple checking. My boys wanted to cover the front spoiler with stickers, so all the stickers were related to the car or a car experience in some way, parts, car show, etc....
ID:	533348   Click image for larger version
ID:	533349   Click image for larger version
ID:	533350   Click image for larger version
ID:	533351   Click image for larger version
IG: #67MoparBird (Follow my rebuild)
1967 Firebird 400
Appeared on Gearz, Season 16, Episode 1, Segment 'What Are You Working On?'
The Following User Says Thank You to DM3 For This Useful Post:
