Old 09-03-2019, 04:25 PM
webfoot's Avatar
webfoot webfoot is offline
Default Anybody have an exploded diagram of a 1962 steering column?
Hoping to get mine disassembled for paint and refurbished.. Anybody have a diagram handy?
Guessing it is tough to find a lower bearing?
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 09-03-2019, 06:38 PM
Stuart's Avatar
Stuart Stuart is offline
Automatic or column shift? Here's a diagram of a steering column for an automatic car from my 1961 parts book, which I think should be the same as 1962. Item 32 on the diagram is described as a "adapter assembly, steering shaft lower bearing". It's part number 5675170, which fits all full size Pontiacs from 1961 to 1964 except any with a tilt wheel (which wouldn't apply for 1962 anyway.)
Old 09-03-2019, 06:45 PM
webfoot's Avatar
I have a floor shift column and a column shift.
Thank you for posting that!
-Jeremy
Old 09-03-2019, 06:54 PM
mgarblik mgarblik is offline
Sort of on the subject. Is there any source for turn signal switches for 61-62 big cars? Mine is fine today but I know it's going to die at some point. I can't find any aftermarket support for that switch, or any NOS ones that are within the price range to buy one for a spare. Thanks in advance.
Old 09-03-2019, 07:01 PM
webfoot's Avatar
I found a thread just today where somebody disassembled a switch, cleaned and re-greased it. I think that would add quite a bit of life to it.
EDIT: found it.
http://forums.maxperformanceinc.com/...40#post4879540
-Jeremy
Old 09-04-2019, 10:24 PM
EDIT: found it.
Thank you for the thread. That switch looks very rebuildable . Looks like the only real snag would be breaking the black plastic nub where the cover latches. Just have to be careful. Looks like a high quality switch.
Old 09-13-2019, 07:44 AM
madeuce50's Avatar
madeuce50 madeuce50 is offline
For the 1962 column bearing check with Les at http://pontiacparadise.com/
Pretty sure he has them.
