Old 09-23-2019, 03:32 PM
webfoot's Avatar
webfoot webfoot is offline
Default 1962 engine harness routing
Does anybody have pics available of where the engine harness goes through the firewall? Also I'm assuming there is some kind of grommet that goes there, is this available?
I am under the impression there is no separate engine harness, as it is all a part of the fuse block.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 09-23-2019, 07:45 PM
Stuart's Avatar
Stuart Stuart is offline
Assuming it's the same as 1961, there is no separate harness, the wires all pass through the firewall on their way to the fuse block, dash switches, etc. The hole in the firewall is on the driver's side, adjacent to the brake master cylinder.
Checking my 1961 parts catalog, I found p/n 537153 for "grommet, main wire harness thru dash." According to the PY online parts lookup database, that part number is good for 1961 to 1963 full size Pontiacs. I don't know if anyone is reproducing it but you may be able to find someone who has a good used one, or a parts car that still has one.
Old 09-26-2019, 11:12 AM
webfoot's Avatar
Thanks, that helps, does anybody have a pic showing which hole on the firewall it goes through?
-Jeremy
Old 09-26-2019, 11:52 AM
Stuart's Avatar
I grabbed this picture online and circled the area in red.
Old 09-26-2019, 03:00 PM
webfoot's Avatar
Great, thanks!
-Jeremy
Old 09-26-2019, 06:12 PM
Stuart's Avatar
If I recall correctly the grommet has more than one hole in it for the wires to pass through, I think two or maybe three.
Old 09-27-2019, 07:53 AM
stucky2947's Avatar
stucky2947 stucky2947 is offline
Here's a pic of mine that may help'
Mike Stuck - "Stucky"
1962 Grand Prix, 408 w/tripower, ported / polished #62s, TH400, 3.42 posi
