My '64 build sheet was trapped in the seat spring of front seat. Fremont car.
I found my fuel pump leak. The last time the fuel pump was installed thread lock was used. Seems the threads are stripped on one of the bolts. Now I'm looking for a timing chain cover. part# 548690, 4bolt water pump type.
Seems my thinking was wrong about the fuel leak. Maybe an oil leak could happen from the stripped out bolt hole, not fuel. My goof. I still have a leaky fuel pump. Now for my timing case cover problem. Anyone ever put a heli-coil in one. This would be the fuel pump mounting hole closest to the block.
The long throttle shaft on the center carb is a leftover from the '60's when most of us used the famous Ansen Ball Bearing Linkage. It had a bellcrank attached to this long shaft and operated the end carbs via that bellcrank and a rod with ball bearing ends. The downside of that setup is that it puts stress in the form of twisting the center carb shaft. The factory mechanical linkage operated the end carbs on the passenger side. There was a version introduced in 1961, and a later version in 1964, which would be perfect for this car.
I recently bought a '64 421 HO block with Armasteel crank and forged rods & pistons. It was assembled by Dan Whitmore several years previous to his death. It has the correct 421HO 45B code on the front of the block. I do not have the 9770716 heads, but they are more widely available than the 45B block. I have not decided what to do with it yet.
Dick,I bought a 63 08B short block,sold the 421 pistons and bought a set of 428s and put a set of 96 heads on it and put in my 62 GP.Runs great.Tom
It's not in common to tap the bad hole to next size, of course pump will need to be drilled, also. I believe stock is 5/16 on newer stuff. Use an Allen head bolt, to make wrenching easier.
I remember when my '64 GTO was new and everyone complained about the factory vacuum linkage. Very few were aware that parts were available from Pontiac to fix the problem, so we went to hot rod shops to buy the Ansen setup. There was no "Pontiac community" back then to share info like there is now. And, most likely, if you went to the parts counter at your dealer, they would not be aware of high performance parts. Most were in the mode of "Why do you need such a big engine in that car?"
I have put helio coils in them and after doing it what you have is stronger/better than when it came from the factory. Put high strength loctite on the coil before you screw it in and it will never come out.
