Old 10-15-2019, 11:06 AM
track73 track73 is offline
Default Intake change ideas?
I’m thinking about changing the intake from the Holley single plane. I have a few pre Smoger qjet manifolds, a 72 with the egr bulge on the bottom and the original 79 with the “D” shaped secondaries. With my #96 heads I realize the easiest is to go with the 79 intake. Would I be sacrificing any power and are there any other issues doing that?
1979 Trans Am WS-6 .030 455 zero decked
flat pistons
96 heads with SS valves
041 cam with Rhoads lifters 1.65 rockers
RPM rods
800 Cliffs Q Jet on Holley Street Dominator
ST-10 4 speed (3.42 first)
w 2.73 rear gear
__________________________________________________ _______________________________
469th TFS Korat Thailand 1968-69 F-4E Muzzle 2
Old 10-15-2019, 12:37 PM
steve25 steve25 is offline
The 72 Intake is the one I would use + there's no gasket issues!
Old 10-15-2019, 03:17 PM
Gary H's Avatar
Gary H Gary H is offline
#96 heads are 71' 400 model heads, Therefore i would use a 68-71 pre smog intake and you're good. No issue with the exhaust crossover also if you use one of those years.
Old 10-15-2019, 03:25 PM
SRR's Avatar
SRR SRR is offline
A 72 isn't going to have an EGR bulge in it. That started in 73.
― Calvin Coolidge
Old 10-15-2019, 04:37 PM
ANDYA ANDYA is offline
It sounds like your currently running a Holley street dominator. Out of curiosity, why do you want to change the intake?
Old 10-15-2019, 05:27 PM
I tried that 20 years ago and it leaked. 70 was the last pre smog intake. I have one and a 68.
flat pistons
RPM rods
w 2.73 rear gear
Old 10-15-2019, 05:30 PM
[QUOTE=SRR;6071916]A 72 isn't going to have an EGR bulge in it. That started in 73.
Then it mus t be a 73. I thought 7 1 and 72_were the same.
flat pistons
RPM rods
w 2.73 rear gear
Old 10-15-2019, 06:00 PM
77 TRASHCAN's Avatar
I've seen one of those "bulge" intakes on a 75.
Shut it off
Shut it off
