Old 03-07-2009, 10:42 PM
vidguy's Avatar
vidguy vidguy is offline
Question Core Support Bushings help
I am replacing my core support bushings. I removed the bushings that were in there. I'm certain they were replaced about 8-9 years ago so they are not the originals. But I have the Energy Suspension kit, and after setting the new ones in. There is quite a bit of difference in height. See my pic.
It's not yet tightened, I just set the parts in and lowered the core support off the jack. They are loose in there...
The old one is in the pic.
Any comments?
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
Old 03-08-2009, 01:20 PM
vidguy's Avatar
OK I figured it out. I was prying between the Bumper bracket and the core support. I hammered a metal wedge in there to hold it apart while I installed the new bushings. And the bumper support stayed in the new lower position.
Where should I pry apart?
James
Work
Details here:
Old 03-10-2009, 03:18 AM
RAM AIR 1967 RAM AIR 1967 is offline
I think you have the bushings for the 70 to 75 core suport and you have a 1976 up core support.
Old 03-10-2009, 10:27 AM
vidguy's Avatar
Hmm That's possible. I got them in there and it all tightened down nicely.
What distinguishes the 70-75 core support and the later core supports?
I can see a date code on top near the hood latch under the paint. I have never scrutinized it but If memory serves me it is a 79 date. I'll check that
James
Work
Details here:
Old 03-11-2009, 03:04 AM
70-75 core supports go under the frame 76 up go on top of the frame.
Old 03-11-2009, 11:50 AM
vidguy's Avatar
Obviously on top there huh? :-)
Thanks for the help.
James
Work
Details here:
