Hughe's flexplate Vs. ATI flexplate
Somehow, I snapped a tooth off my ATI flexplate Saturday night during rounds. Seems like every 2-3 yrs this happens with no clue why.
Is anyone using the Hughes flexplate? Its half the cost of the ATI but I'm also sure its probably made on the other side of the Pacific. The ATI is a nice piece and I have no objections getting another one, just looking for an alternative if possible.
74 GTO Bracket/Street car and another 74 for the wifey to race with! 70 GTO 400, 4 spd, #'s matching and a little to nice for me to own. Friendship is like peeing your pants..everyone can see it but only you can feel the warmth! |
Can’t speak for hughes but after losing some teeth on a Chinese flexplate, I had real good luck with JW the wheel.
http://www.jegs.com/i/JW-Performance/564/93012/10002/-1 |
TCI
GTO George |
6.98 @ 199mph 4.53 @ 164mph |
I’ve cracked a few around the bolts. I have an ATI in there now
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas |
Just got my TCI back from re-cert and everything looked good.
Matt 70 GTO 400 4-speed "Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge |
Decided to just go with another ATI and chalk the lost tooth to an act of God. Just couldn't purchase the Hays/Hughe's knowing that its more than like a chinese piece.
My TCI knocked the teeth off as well.
Crest has been shown to prevent tooth decay in a program of regular oral hygiene, and a professional care program...………...
It's not like the ring gears are made of anything other than cold roll steel. I have actually welded up broken teeth on flexplates and filed them back to original contours, and had good luck with the repairs holding up in daily drivers. |
For between $200-$450 bucks, I'd be looking at some way to salvage that part for a relatively minor problem, but I never did like replacing parts I could repair myself.
PRW Platinum series on mine.
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
Got a link ? I assume the "good" China stuff. There is such a thing but have to be careful. I bought one of their non SFI balancers a long time ago, POS.
I have a Hawks SFI flexplate in a box, doubt I will use it with the new build. Trying to come up with something in the middle between mine and the billet piece. That this is awesome, that is one big hunk a billet they start out with. Bigger than one you would use to make a crank. |
Scroll down, see full item description.
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" Last edited by Old Goat Racer; 06-10-2018 at 11:31 AM. |
I lost a tooth on a couple of TCI flex plates over the last ten years or so. I switched to the ATI based on threads posted here on PY. I’m into my third season (I think), on the ATI. So for so good with the ATI, however; I think the stress of cranking a hi compression motor work hardens the teeth over time, leading to eventual failure. I don’t think there is anything you can really do about it. At least that’s my theory.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
