Old 10-05-2010, 08:53 AM
1972GRANDPRIX1962 1972GRANDPRIX1962 is offline
Default 1972 455 Carb
Hello,
My quadrajet has an issue. Front of carb has a large bolt that screws into it, in which the fuel line screws into that. This is the piece that holds the fuel filter. Anyhow, mine is stripped.
Can somebody recommend a business that can rebuild the carb to new and also heli-coil a new thread?
I live in Seattle and most places do not touch carbs, unless I am wrong... fill me in where they are hiding.
Ron
Old 10-05-2010, 09:35 AM
MescaBug's Avatar
MescaBug MescaBug is offline
Dont know about Seattle, but you can ask Cliff Ruggles. Carb guru, and member here.
Old 10-05-2010, 10:06 AM
Default Thanks
I sent him an email. Thanks for the help.
Ron
Old 10-06-2010, 09:24 AM
David Brown's Avatar
David Brown David Brown is offline
Send a message via ICQ to David Brown
I assume they still make oversized fitting to screw into the carb body if it's not totally shot. NAPA might have them. A lot of them got damaged threads when the fuel line was tightened without keeping a wrench on the large fitting.
Old 10-08-2010, 12:03 PM
shoebox1.1 shoebox1.1 is offline
they have the repair fitting at auto zone and oriellys. is your original fitting "short" or long? i need the short one for my carb.( maybe your fittings threads are ok?)
GOD does business with people that mean business!
