1982-92 TA & FB TECH 1993-2002 TA & FB Tech is now part of the new Late Model Section of the PY Forums. Click this link to check it out.
Old 05-11-2005, 08:37 AM
tlc4ever tlc4ever is offline
Hello,
I have a 1979 Trans Am (Olds 403 engine) with problems starting it after it's been running. The battery will be fully charged, but if I turn it off after running it for 10 or 15 minutes, it won't start back up. It acts like the battery is almost dead, slowly turning the engine over, but then it runs out of juice. If I wait a couple hours, it starts right up. I've already changed the battery and solenoid but still no help. Any ideas?
Thanks,
Tom
Hello,
Thanks,
Tom
Old 05-12-2005, 02:37 AM
Colin's Avatar
Colin Colin is offline
Location: The ObamaNation we once called the United States of America
Heat soak.........get a heat shield for the starter. One of the wraps from Summit or the like will work fine.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."- General George Patton
"Perpetual peace is a futile dream."-General George Patton
"I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them."-Thomas Jefferson
"Any society that would give up a little liberty to gain a little security deserves neither and will loose both."-Benjamin Franklin
Old 05-12-2005, 05:22 AM
olds olds is offline
Get a good starter. I'm using a Mondello starter for 455 olds. Works great. Might try a 455 starter. My starter is wrapped too
olds
Old 05-12-2005, 10:16 PM
Colin's Avatar
Yeah I had a 403 car, mildly built with headers and heat soak was a problem until I used a good starter with a wrap.
Old 05-13-2005, 08:40 AM
Thanks. If anyone else has some additional information, please let me know. Thanks again.
Old 05-20-2005, 07:05 PM
thepontiacman's Avatar
Also replace the solenoid spring with a heavy duty spring available through GM. This will make the solenoid engage when Hot. Then put a shield on the solenoid. Make sure you have a higher amp battery.
I even have bigger battery cables.
I run a 455 Pont. with RA3 Exhaust manifolds and air cond. It never fails to start.
thepontiacman@yahoo.com
Old 05-25-2005, 11:28 AM
limejudge limejudge is offline
If you ever find yourself in a situation where the hot soak problem has you stranded-take some water or any cool liquid(Coke,Pepsi,etc) and pour it on the starter solenoid. Anything that will cool the starter will get you going.I have even crawled under my car and spit the cold liquid onto the starter solenoid! It looks really retarded-but it works! Beats sitting around until the damn thing cools down!
