Old 01-28-2020, 07:33 AM
TheGrudge TheGrudge is offline
Default A body frame boxing/bracing - necessary?
....if you’re fitting a typical welded 6pt cage or is it just unnecessary weight? A cage is mandatory at any respectable ET these days, so that’s a given; but is there any benefit to having both a cage & boxing the frame? Anyone done both?
I’m thinking that the cage would add more stiffness than adding extra plates to the frame on the same/existing plane(s)?
Feel free to educate me!
Thanks in advance.
Old 01-28-2020, 08:03 AM
Mike Davis's Avatar
On a cage the frame has to be boxed where the bar meets the frame to pass tech and be certified. On a 6 point roll bar not needed but will help stiffen the frame.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
The Following User Says Thank You to Mike Davis For This Useful Post:
Old 01-28-2020, 10:40 AM
charlie66's Avatar
The bar will be only as strong as whats under it. Id box it no doubt
My Half AN Injun.....
The Following User Says Thank You to charlie66 For This Useful Post:
Old 01-28-2020, 11:32 AM
ZeGermanHam's Avatar
You might as well just box the frame. I just finished boxing my frame this past weekend, making all of the plates myself from scratch. Took some time to fit everything, but it was cheap and relatively easy.
ID:	530247   Click image for larger version
1998 BMW 328is (track rat)
Old 01-28-2020, 01:26 PM
charlie66's Avatar
Nice job!
Old 01-28-2020, 01:36 PM
Originally Posted by charlie66 View Post
Nice job!
Thanks! I'm a novice welder, so it was a fun learning experience. Cost was about $80 for the raw materials, versus over $300 for the premade kits available that no doubt require nearly as much time to dial in the fitment. Money well saved, IMO.
Old 01-29-2020, 09:13 PM
NO67GTO's Avatar
NO67GTO NO67GTO is offline
I boxed 6" of the frame with 1/8" plate where ever the bars were welded to the frame
Sent from my Pixel 3 XL using Tapatalk
Giving To Others!!!
V.P. Pioneer Valley GTO Association
www.pvgto.com
67 Lemans 455 best et. 12.023@ 111 mph LVD 9/2008
68 GTO H.O. in progress?
Old 01-29-2020, 09:53 PM
NO67GTO's Avatar
Forgot pics boxing plates
Giving To Others!!!
www.pvgto.com
Old 01-30-2020, 01:21 AM
Joe's Garage Joe's Garage is offline
Default Just find a same-year factory CONVERTIBLE A-body frame - they're already boxed!
But they're probably a little heavier........
Old 01-30-2020, 06:25 AM
So I’m guessing you did that all with the body in place? I have to patch the floor so I figured I’d cut the floor out and do any boxing at that time, then weld in the new floor & build the roll bar or cage - unsure at this time exactly how far I’ll go with the bar/cage - dash is out so... I’ve seen some really tight fitting cages lately with removable bars and rear seat in place, can barely see them from the side.
Old 01-30-2020, 06:34 AM
NO67GTO's Avatar
Yes I did the boxing with only a 6" x 6" hole in the floor pan, it gave me pretty easy access.
I bought bars that go thru the package tray and still retain my rear seat for looks.
Giving To Others!!!
www.pvgto.com
Old 01-30-2020, 06:46 AM
NO67GTO's Avatar
Also I did all the fitting and notching myself. Now I see why shops quoted me 1500- 2k for installation took along time to get it all fit, especially the swing out door bars. I got swing outs cause it's still mostly a street car
Giving To Others!!!
www.pvgto.com
Old 01-30-2020, 10:59 AM
73 TRANSAM 73 TRANSAM is offline
That's some nice work! I would wear some long sleeve when your doing TIG welding. That is not good for your skin even though there is no spark scatter like a MIG. Great job!
Old 01-30-2020, 11:19 AM
NO67GTO's Avatar
Meh I like to live on the wild side. Lol
Giving To Others!!!
www.pvgto.com
Old 01-30-2020, 05:15 PM
NP. Didn't want to sound like ur Dad.
The Following User Says Thank You to 73 TRANSAM For This Useful Post:
Old 02-06-2020, 06:05 AM
I agree, some nice work indeed! Off topic one of my closest friends was raised in Pioneer Valley - pity he’s a MoPar guy!
