Stan
Just blended the larger area into the bowl. I ported the heads with the smaller valves years ago.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
3 1/2 Stainless, Mandrel bent with X Pipe.
Car runs the same with exhaust as without.
66 GTO Nostalgia Super Stock/Street Legal Car 421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99 Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
You have it made or is it a kit? If kit what brand?
I bought the X pipe kit from Pypes, Mufflers are round Ultra flow welded.
https://www.summitracing.com/parts/pye-xva14 https://www.summitracing.com/parts/wlk-17224
Mike Did u run it with 3" before or no?
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,7.33@94.55-11.502@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32 M/T 275/60 ET SS Drag Radial 2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's |
Not with the current combo.
Thread Tools | |
Display Modes | |
