? long shifter H pattern ?
hey folks
68 gto factory 4sp car original NICE car 600hp/600tq new m23z without cuttin much if any do ya think long h- pattern is best ? no lift right foot street / traffic/ houston full passes late nights and dragstrip trips please help me get shi$t together ! thank you for helpin |
I have the same question. Long or Hurst recommendation and why?
I have a Long H-pattern on my G101A transmission and it’s light years better than a Hurst (the old ones are better than the newer ones IMO). I’m not sure a Long will fit without tunnel modifications tho (I had to make a custom hump and modify my floor for the transmission and shifter).
subscribed ...
GILLIGAN, what rear end ratio are you running with the m23z?
67 GTO with original floors initially so with a 68 it might differ some. Hurst shifters pivot, but a Long shifter pushes/pulls to change gears; look at some pictures and it’ll make sense.
I have a factory original 1968 GTO HURST four speed available if you are interested. PM me if you would like photos or additional details.
Tim john--- |
Is the M23Z considered “pro shifted”. Meaning face plate engagement or non synchronized dog ring? I can’t believe how impossible it is to miss a shift with my long shifter. But yes floor mods are mandatory with it.
26 tall stickey swapped tonight and ran 28 tall stickey |
mine works good considering long H pattern |
is your LONG the H pattern ? |
appears to mount higher and to drivers side on H pattern Long |
running "geometrically" equal gears
gear set # 334 |
the only experience I ever had with a Long shifter was in a Robert Yates Busch Grandnational car. Excellent shifter, more precious than a Hurst.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear 85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book. 87 F350 6.9 4 speed dually A poor man has poor ways. |
Mine was straight shot and had straight heim joint linkage. Unfortunately the floor mods were mandatory. not sure if you can even find a really good shifter that will performance nice as a long shifter without some floor modifications. the actual landing of the shifter didn’t fit well in my console either was 1968 GTO. I haven’t done any shifter research lately but maybe they make one that isn’t so intrusive.. I can’t see how it would shift as well. Now it’s hard to find yourself justifying cutting up the floor but when I was 20 years old cutting up the floor was just part of normal modifications for us then.
Thread Tools | |
Display Modes | |
