#41
years ago I tried the manifolds on a 68 the drivers side didn't fit --- had to threaten a "drive down and kick your ass" before they would refund my money
#42
When I put RA/HO manifolds on the 81 TA there were several that had to be taped in the manifold as it was put up as the bolts were too long to get in past the frame and upper A arm. So not a piece of cake on those either. and it closer to the starter than any of my headers.
#44
Header install
Hello all, years ago my buddy and I were running ram IV's .He in a 65 and me in a 64 GTO .I bolted the headers to a 614 using all the bolts except number 4 . Then we welded a nut to the header flange and used a grade 8 bolt from the top.It was still a pain to install them but this was easier on number 3 tube.
#45
I agree with Skip on the RA headers. After years of installing nothing but headers it was necessary to shift gears and get the correct assembly order for the RA installation. Nothing serious, but setting manifold in place and finding out the bolts had to go in first, then having them drop out until we taped them in place on the manifold. Just depends on what you are used to.
Dougs have never given us a problem unless there was previous accident damage, but that doesn't mean that the jig didn't slip and the set you purchased were fubar'd. We've installed probably nine sets on '67 GTO's and six or seven on 66's, and a couple on 65's. Record for my son for a '67 was 18 minutes from headers in the box until fully tightened down on the engine. Other side of the record was over four hours on our 2+2 headers -- just one of those times where nothing went right.
#46
Header install
Hello again, in post 44 I forgot to add the bolt I installed was 5/16 to go thru the existing tapped hole. Sorry it was 5 am .
#48
Just did a install on original RA II manifolds on 68 GTO. I had removed a set of repo RA IV 2.5" manifolds that were on car and fit much tighter. What I found that worked well was to put a stud in two holes near opposite ends that did not interfere with A arm or frame. Place gasket in place over studs, used small clips on opposite ends to clamp gasket in place on edge of head. Removed studs. Then placed front manifold bolt hole (closest to radiator) to respective mounting hole and put bolt in about 2 to 3 threads. Then gently let manifold rest on crossmember and put the bolt in that had interference with chassis and raised in to place to also engage 2 to 3 threads. Removed clamps holding gasket. Then with manifold in place was able to finger tighten all the bolts. I did remove motor mount bolt on side I was working on and placed floor jack and board under oil pan offset to side of engine I wanted to raise. Gently raised engine on that side as high as possible (loosen other motor mount bolt so engine can rotate). I was able to remove passenger side and do install from top. However driver side had to come out and in through bottom due to steering shaft. Also driver side I had to remove starter and clutch countershaft as well. I did an install of Dougs on 69 Firebird automatic car and was amazed how easy they went in. Raising the motor on the side you are working on helps a lot.
#49
I am confident the Tri-Ys will fot after talking to them though. |
#50
Scott I believe the ones I took off the car are the RARE versions. They were on the car when I bought it. The car was raced in factory stock events. I do have a receipt for the purchase at TA Nationals a few years ago. It does not have a description other than "manifolds". Attached a few pics of them. I do know a person who did work on this car and he posts here sometimes. I will see if he knows for sure. I will probably be selling them.
Thread Tools | |
Display Modes | |
