Old 10-21-2020, 12:14 PM
RA1John RA1John is offline
Default Valve Cover Bolts
After doing some research, it would seem that valve cover bolts used from '64-'68 were black (phosphate, zinc or cadmium?) where as '69+ were silver zinc or cadmium.
Going through my fastener stash from various projects & parts cars over the years, I've come up with a few variations. Would be curious to see pix of original restored or survivor assembly line bolts.
John
'68 Firebird Ram Air 4-spd Conv.
John 14:6
Semper Fi
Old 10-21-2020, 02:05 PM
gto19's Avatar
gto19 gto19 is offline
Here’s a pic of mine off my 67 gto
ID:	551926   Click image for larger version
Old 10-22-2020, 05:23 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
My ‘65 has 8 letter “D” flange head bolts.
My ‘66 has 6 letter “E” and 2 letter “L” bolts.
Maybe whatever was in the bolt bin on the assembly line that day.
Chris.
ID:	552059   Click image for larger version
ID:	552060   Click image for larger version
Old 10-25-2020, 09:31 AM
rockdoc's Avatar
rockdoc rockdoc is offline
My early '67 GTO has all "W" bolts, just like your far-right pic.
Dave
Old 10-25-2020, 04:59 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
My late '67 has 7-D's and 1-E.
Grant
Old 10-25-2020, 05:23 PM
geeteeohguy's Avatar
Have used Birchwood Casey cold blue for bolt restoration. It's a gun blue, available at gun shops, and won't peel or chip or come off like some paints and coatings. It looks just right, too. YMMV.....
Jeff
Old 11-08-2020, 11:56 AM
Jason67's Avatar
Jason67 Jason67 is offline
My early Feb. Pontiac plant built 67 uses the "D" marked flange bolt, 8 of them. The bolt head is not recessed like in the previous pics, but flat across the top (other than the raised "D") with no edge around the hex.
Jason
