Stan
Just blended the larger area into the bowl. I ported the heads with the smaller valves years ago.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
3 1/2 Stainless, Mandrel bent with X Pipe.
Car runs the same with exhaust as without.
You have it made or is it a kit? If kit what brand?
I bought the X pipe kit from Pypes, Mufflers are round Ultra flow welded.
https://www.summitracing.com/parts/pye-xva14 https://www.summitracing.com/parts/wlk-17224
Mike Did u run it with 3" before or no?
Not with the current combo.
