Old 11-15-2020, 06:45 PM
Terry M. Hunt Terry M. Hunt is offline
Default ‘66 GTO rag joint
Looking for a correct reproduction of this part for my power steering equipped ‘66 GTO. Photos attached of my original part. Rubber disc has a sizeable split in it. Ames shows a replacement part S128J in their catalog, but it is listed as an After Product, so it is not a reproduction and does not look like the original part as shown in my pictures. There are many, many aftermarket versions of this part available, but I haven’t found an accurate reproduction yet in my searching. Somebody save me more hours on line looking at the same “wrong” stuff, and tell me where you bought an accurate reproduction of this part.
ID:	554007   Click image for larger version
Terry Hunt
"He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr.
Old 11-15-2020, 09:59 PM
fyrffytr1's Avatar
If you can't find the original style you may want to consider this repair kit from Corvette America.
https://www.topflightautomotive.com/...er-repair-kit/
Old 11-15-2020, 10:19 PM
Yes, I looked at a couple of these type kits. The original rag joint has a small diameter and a large diameter stud that engages two similar sized slots in the flange that attaches to the end of the steering shaft. These two studs are riveted in place(see pic below). The replacement studs in these kits appear to be designed to bolt in place with a nut and lock washer. No doubt this will function with no problem, but instead of the large flat rivet heads that appear on the original part, I would now have two threaded studs retained by nuts and lock washers. At least that’s how the parts in these kits appear to me. Am I missing something?
Terry Hunt
Old 11-15-2020, 10:25 PM
Oops, forgot to ask what is the purpose of the short wire that connects between one of the through bolts and the adjoining stud?
Terry Hunt
Old 11-15-2020, 11:09 PM
RedDirtRoad RedDirtRoad is offline
I believe it’s the ground for the horn
Old 11-15-2020, 11:36 PM
fyrffytr1's Avatar
Could you use the rubber biscuit with your hardware?
Old 11-16-2020, 12:36 AM
One end of the small and large studs is riveted in place(peened over) to retain it. No way to remove and reuse them with another rubber piece without destroying them. Replacement studs in kits appear to be designed to be retained by nuts, so they work but won’t have the same look as the riveted version. Yeah, it’s all pretty anal but that’s the design/look I’m trying to duplicate.
Terry Hunt
