New list - Must use PMD heads and Block
I have been ask for another list. With the only requirements being the engine has to have used PMD head casting, and PMD block casting.
So post up your combinations. Thanks Stan
Going back to the early 90's here. 3200# 69 GTO 455 (469) untouched 614 heads 276-280 .440 Comp roller, Warrior intake, 9375 Holley. Would run 10.90-11.00's at our 4250' track.
Jack Ferris RestoRacing LLC www.restoracing.com Sandy, UT --------------------------------------------------- |
Do you happen to remember the MPH? Thanks, Stan
Had a 84' Trans Am tube chassis car back in 1987. Pretty light, 2400 lbs. Ran a 455 block, factory 455 crank, hand ported RA IV heads, Warrior intake. Best time was a 9.30 at 139 mph
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
Stan- 122-124 for the mph
Is 2400# with driver? Thanks Stan
I bought a combo from 9secdport on here years ago. 59 cc 62s, 280/284 sr .440 lobe ,victor, 1050 dominator. 3300 lbs, he went 9.60 140mph . 15:1 462.
Illinois Outlaw Gassers 6.27@107 9.97@131 |
1970 Trans Am
10.68 at 125 mph '70 400 block / 462 CID 4.182" bore 4.210" stroke ( factory crank w/ mains cut to 3") 6.625" rods 1969 #16 d-ports 12.49:1 compression Ultradyne solid roller 264/ 271 @ .050" .4176" lobe lift / 1.65 rocker ratio 108 LSA Victor intake / Brad Urban Stage III 750 Holley 1-7/8" headers 626 hp @ 6400 rpm on a generous dyno TH400/ 8" converter/ 4.33 gear 28-10.5-15w M/T slicks Race weight about 3620 lbs. .
474 cu.in. D-Port #62 - 12.75 to 1 , Victor manifold, 1050 Dominator, Lunati SR 268/275@ .050, W/ .604 lift. cam. , 1-78" to 2" step headers. , 3" exhaust over the rear axle. 3550LB race weight 1967 Firebird
10.55 @ 129 mph |
Thank You. Did you ever run the motor? Heads and Block List. http://www.magneticlynx.com/carfor/pont_pmd.htm Stan PS I will add these other later tonight.
1969 Lemans weighing 3680lbs in the early 90s...455 with 191 heads, 3680lbs, working A/C, 4.10 gears and 10" tires...6.66 in the 1/8th, 10.20s in the 1/4.
Stan I ran the heads and rest of top end, but without domed pistons and aluminum rods that he ran. I was shifting way before him as well. and only 13:1. I was 10.54ish at 125 at 3500 lbs with a 3.73 and 28" tire.
Thanks everyone.
Stan
There are a few guys that are not on the net I will try to contact.Nunzi,Ric Johnson,Bill Blair for a couple.Will also see what Dave Johnson ran.Before Wenzlers.Blair and Nunzi only ran factory stuff.All 4 ran 980 heads with factory blocks.Tom
Also Brother Leak,Stienbeck,and the Nor Cal guy who's name I can't remember ran RA V Astras with stock blocks.Tom
68 firebird 3000 lbs 455 ram air 4 heads hyd flat tappet cam 1050 carb wenzler intake went 9.99 @132 in 1995
2008KRE Q16 Winner 2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam Hoffman Racing building and racing Pontiacs for 35 years |
Just curious does this list include boost?
Rudy Diphous(spelling) was the other Astra racer.A board member I believe owns his car.Tom
Thank you the information has been added. PMD Heads and Block List. http://www.magneticlynx.com/carfor/pont_pmd.htm Stan
Thread Tools | |
Display Modes | |
