Scott,
YES, as long as that information is supplied. Stan
Thanks, that would be great information to have. Weren't any of your builds done use Pontiac heads and blocks? Stan
Name: Kristinn Rudolfsson
Car: 1969 Custom S Location/time: Iceland 2013 ET/MPH/LBS: 8.93 @ 154.. 3650lbs 462 ci.(4.18*4.21) Factory 455 cast crank '70 400 block and '71 #197 heads. Blow through turbocharged combination on 275 radials. 85mm single turbo, a2w setup and avgas for fuel. Video of pass: https://www.youtube.com/watch?v=j9pwP1HlAX8 Thanks, Kris.
*** THE BIG BRACE is here *** |
Around 2550 lbs with driver
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
Nice combo, any pics of car?
Thank you. I have added your information. PMD Heads and Block List. http://www.magneticlynx.com/carfor/pont_pmd.htm Stan
John,
He posted a link to the run. Good looking car. Stan
Gary,
Thank you. I have made the changes. PMD Heads and Block List. http://www.magneticlynx.com/carfor/pont_pmd.htm Stan
Stan in close to 60 years I have only built one non factory head engine.All have been factory blocks.Tom
Before changing to e heads, victor and 1050 10years ago. Went 10.30's at 129 with home ported 62's. performer rpm and 850 holley. With a solid flat tappet cam 260/270. 3400lbs. same convertor that I'm still running. I do remember cranking compression was in the 220lb range vrs the 180lbs I have now the the roller cam.
I remember that I had to change the heads because the 62's cracked into the water jacket. Someone (me) got carried away porting them. |
Thanks Stan
Stan, thank you for these lists. Great resource.
I guess Marty's accomplishments needs to be added (even if redundant to other lists). -- Marty Palbykin '70 GTO Twin TurboCharger Iron D Ports Stock Block 406 6.95 195 - - - 2950 US 131 Michigan 1996 -
79 Trans Am WS6 71 Formula 72 Formula 71 Firebird 69 Firebird |
Mid 90’s,
‘68 Firebird full interior, leaf spring, 29.5x10.5 Filled 455 block with splayed billet caps Ported 614’s 67cc Crower billet 4.21 crank (my first one😉 Comp 660 solid roller cam Eagle h-beams, Venolia flat tops Wenzler tunnel ram/two 850’s Ran 9.92@138 3540lbs with me in it at around 3200 ft |
400 block honed to 4.125" = 401 c.i. (had 4 1/8 J E blower pistons on hand), 10:1 '61 SD crank w/center counterweights added Old M/T aluminum rods -16 heads, minor porting Small-bore 6-71, 8% over crank speed Old 4-port Hilborn injector and -1 pump, methanol Vertex mag locked at 31 degrees Very old flat tappet Crane cam Headers-by-Ed CrowerGlide 3-disc 8" full-centrifugal clutch Inline 'JCG' quick-change 9" Strange 3rd member & axles, billet 4340 4-pinion carrier, 5.00 9310 gears 300' in 10 seconds, pulling 14,000 lb. sled (typically 8,200 RPM)
Stan
Thank you for the information. Stan
#38
It would be great if the Pontiac Stock and SuperStock racers would post up, but I am guessing that is pretty SSS (super secret stuff).
The Following User Says Thank You to hojs69 For This Useful Post: | ||
#39
So I would save to say this build had PMD RAV heads Quote:
#40
RA5TTF!
GTO George |
