#81
Thanks for reply. I have added both of your engines that Steve posted links to. I will take a look at the thread you linked to when i get a few minutes. PMD Heads and Block List. http://www.magneticlynx.com/carfor/pont_pmd.htm Stan
#82
1965 GTO. all steel, all factory glass, 3580lbs with driver
413ci 11.75 to 1 670's ported to flow 265cfm Ported Warrior intake, Brad Urban 1050 Dominator 279/283 @ .050 104 lobe sep cam dynamics .650" lift TH400 8" ATI 4500 stall 5.14 gears with 31" tall tires. 10.23 @ 130mph in 1997 |
The Following 3 Users Say Thank You to Dave Bisschop For This Useful Post: | ||
#83
Awesome to see u post Jim!!! You and your cars performance is what started me on my journey with the grandville!
#84
Thanks for information. I have added it to the list. PMD Heads and Block List. http://www.magneticlynx.com/carfor/pont_pmd.htm A question if I may? On another forum I am on some are saying it is very hard to find cores that can be ground at 104 LSA. Then (1997) or now have you found that to be the case? Thanks, Stan
#85
Hi Stan, not sure why they would say that Comp Cams and Lunati used to offer cams similar to Dave's as a shelf grind. They are still listed in their catalogs. You are limited somewhat with the LSA using a standard core but usually 104-114 are easily doable. Didn't mean to answer for Dave, maybe he'll have some additional input. |
#86
Comp Cam card of roller I used for 455 SD engine. It was grind used by HO Racing in their SD Trans Am race car. (now owned by Clegg I think) Used to make the low compression of the SD heads work good. It was very popular in the 80's.
#87
Some one mentioned Stock and Super Stock so I'll post my two combinations . '68 Firebird Stock Eliminator, 9 in. slick, 4 speed car.
400 D- port 62 heads,.035 over on the bore,stock stroke. 421 lift cam , stock intake and Q-jet. 10.47@126.61 @ 3340 lbs. 350 HO D- port 18 heads ,.075 over on the bore. Everything the same as the 400 except the bore (cubes) and valve size. 10. 80 @123.73 @3300 lbs. Last edited by F/S GTO; 11-28-2020 at 09:36 AM. |
#88
Gen 2 T/A
3225 race weight 474 (455 block) 12-1 Comp roller 272/280@.050, .421/.422, 109*, 4-7 swap R/A II’s (low 290’s intake) Dominator / Victor w/1 1/2” Wilson tapered 2” super comps Turbo 400 9” spragless 4800 4.33 w/ 32x14.5W’s 6.08-9@112 1/8 mile Haven’t been on 1/4 track with this cam Currently set up for 6.50 index.
Thanks. Stan
#90
Thanks Stan
#91
#92
#93
This list, we have power adders at the top, then NA. How about the NA broken down to pump gas ?
#94
http://www.magneticlynx.com/carfor/pont_gas.htm Stan
#95
Stan,so the pure PMD head-blocks are mixed in with aftermarket heads-blocks?Tom
#96
There are 2 lists N/A Pump Gas List. http://www.magneticlynx.com/carfor/pont_gas.htm PMD Heads and Block List. http://www.magneticlynx.com/carfor/pont_pmd.htm Stan PS Tom, I just did a quick scan of the pump gas list and the only 2 engines I saw with PMD Heads were yours.
Stan Weiss/World Wide Enterprises Offering Performance Software Since 1987 http://www.magneticlynx.com/carfor/carfor.htm David Vizard & Stan Weiss' IOP / Flow / Induction Optimization - Cam Selection Software http://www.magneticlynx.com/DV Download FREE 14 Trial IOP / Flow Software http://www.magneticlynx.com/DV/Flow_..._Day_Trial.php Pontiac Pump Gas List http://www.magneticlynx.com/carfor/pont_gas.htm Using PMD Block and Heads List http://www.magneticlynx.com/carfor/pont_pmd.htm Last edited by Stan Weiss; 11-28-2020 at 08:08 PM. Reason: Added PS |
#97
ps, both my n/a and boosted combos used pump gas-but with octane booster added, does that count!
#98
Stan
#99
Please note that the same combination can be listed on more that one list. A combination that is both pump gas and has PMD heads and block will have 2 red vertical rules in that list's last column.
Stan
#100
Stan,
I noticed you did not have my best timeslip on your new list. See attached.
Jim www.raceV8s.com 1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th. |
