Old 11-17-2020, 11:54 PM
GILLIGAN GILLIGAN is offline
Default ? long shifter H pattern ?
hey folks
68 gto
factory 4sp car
original NICE car
600hp/600tq new m23z
without cuttin much if any
do ya think long h- pattern is best ?
no lift right foot
street / traffic/ houston
full passes late nights
and dragstrip trips
please help me get shi$t together !
thank you for helpin
Old 12-02-2020, 05:49 PM
straycat's Avatar
straycat straycat is offline
I have the same question. Long or Hurst recommendation and why?
Old 12-02-2020, 06:20 PM
younggto younggto is offline
I have a Long H-pattern on my G101A transmission and it’s light years better than a Hurst (the old ones are better than the newer ones IMO). I’m not sure a Long will fit without tunnel modifications tho (I had to make a custom hump and modify my floor for the transmission and shifter).
Old 12-02-2020, 06:29 PM
Scott Thelander's Avatar
subscribed ...
Old 12-02-2020, 07:15 PM
ANDYA ANDYA is offline
GILLIGAN, what rear end ratio are you running with the m23z?
Old 12-02-2020, 08:37 PM
67 GTO with original floors initially so with a 68 it might differ some. Hurst shifters pivot, but a Long shifter pushes/pulls to change gears; look at some pictures and it’ll make sense.
Old 12-03-2020, 09:03 AM
Tim john Tim john is offline
I have a factory original 1968 GTO HURST four speed available if you are interested. PM me if you would like photos or additional details.
Tim john---
Old 12-03-2020, 09:54 AM
Darren 639's Avatar
Darren 639 Darren 639 is offline
Is the M23Z considered “pro shifted”. Meaning face plate engagement or non synchronized dog ring? I can’t believe how impossible it is to miss a shift with my long shifter. But yes floor mods are mandatory with it.
Old 12-04-2020, 02:04 AM
3.90
26 tall stickey
swapped tonight and ran
28 tall stickey
Old 12-04-2020, 02:05 AM
Tim john---
thank you
mine works good
considering long H pattern
Old 12-04-2020, 02:07 AM
mine was built to shift w/clutch
is your LONG the H pattern ?
Old 12-04-2020, 02:10 AM
the straight shot looks right
appears to mount higher and to drivers side
on H pattern Long
Old 12-04-2020, 02:20 AM
running "geometrically" equal gears
gear set # 334
Old 12-04-2020, 11:13 PM
A.W.Dille A.W.Dille is offline
the only experience I ever had with a Long shifter was in a Robert Yates Busch Grandnational car. Excellent shifter, more precious than a Hurst.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear
85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book.
87 F350 6.9 4 speed dually
A poor man has poor ways.
Old 12-06-2020, 11:42 AM
Darren 639's Avatar
Mine was straight shot and had straight heim joint linkage. Unfortunately the floor mods were mandatory. not sure if you can even find a really good shifter that will performance nice as a long shifter without some floor modifications. the actual landing of the shifter didn’t fit well in my console either was 1968 GTO. I haven’t done any shifter research lately but maybe they make one that isn’t so intrusive.. I can’t see how it would shift as well. Now it’s hard to find yourself justifying cutting up the floor but when I was 20 years old cutting up the floor was just part of normal modifications for us then.
