Old 04-26-2006, 02:24 PM
fastgto fastgto is offline
Nice, real nice.
Old 08-10-2006, 12:56 PM
spartazoo's Avatar
spartazoo spartazoo is offline
More update photos. The trans tunnel is in. I have never done any fabricating so I am pretty proud of this. The turbo 400 fits like a glove in there.
Right now I am fabricating the trunk floor to accept a fuel cell sumped through the floor.
I am not as far as I had hoped to be by now but it is coming along. I am expanding my business into a new market and we have a new baby due next friday...time is not on my side right now.
ID:	61575   Click image for larger version
ID:	61576   Click image for larger version
ID:	61577   Click image for larger version
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
1966 GTO Hardtop - PS 14.84 @ 97mph
Old 08-10-2006, 01:21 PM
spartazoo's Avatar
Another update or should I say warning...
Since this delema is now over, I am going to give everyone a big heads up.
Wheels can be a major issue when building these cars. Building a SD clone requires plain steel narrow wheels on the front and wider plain steel wheels on the back. So instead of searching high and low for wheels that would fit I called Stockton Wheel in California and ordered custom backspaced 8x15x4.5 for the back and 5x15x4.5 for the fronts. I set my rearend in place and did a wheel mockup to get the back spacing right. Every thing is cool right...Wrong.
I receive the 8" wheels first and attempted to put them on the car. They will not fit. So I measure the lug spacing and it is 4.75x5. My order ticket that came with them is correct. So I call.
I get this guy on the phone that is not sure what happened and is as surprised as I am, so he puts me on hold. This older gentlemen picks up the phone and as soon as he does starts yelling at me. "I changed that order in the shop, NO Pontiac Tempest ever came with 4.5" bolt patterns"..."You ordered wrong or you are trying to pull a fast one"..." I owned one brand new and it had a corvair bolt pattern" I literally got into a verbal altercation with this guy about the wheels that I had ordered. He refused to fix the problem saying that "I must have changed something to have a 4.5" bolt pattern"
Finally after emailing this AHOLE multiple links from the web outlining the bolt pattern, he agreed to make what I ordered. He did not admit fault but made me new wheels.
The intial order for the wheels was placed on Nov 7th of 2005. I received the last two wheels two weeks ago.
If you have to order from Stockton Wheel be prepared for mistakes, rude service, run arounds, and plain lies!
Consider yourself warned.
Old 08-10-2006, 02:34 PM
63Banshee's Avatar
63Banshee 63Banshee is offline
After you get your new rims let them know they lost 2 customers, not just one... so far. It's a shame cause it's not easy finding a shop that will mod steel rims.
The car looks good. When do you expect it to be on the road?
Old 08-10-2006, 03:04 PM
BVR421's Avatar
BVR421 BVR421 is offline
thats a great looking project!
On the upholstery? who has seat covers for a 63? I admit I havent looked very far yet but I need a set for a 63/buckets.
Old 08-10-2006, 03:08 PM
spartazoo's Avatar
Did you attempt to use Stockton as well? They are awful to deal with. I hardly ever use this word but they are pure liars plain and simple.
On the road? I am not sure that by the time this thing is done, it is going to be much of a road car. Having said that, I have nearly everything outside the small stuff to finish it. I hope to have it in paint by Jan 1st. and ready for the summer of '07. Right now it is Norwalk '07 or bust...
Old 08-10-2006, 03:10 PM
spartazoo's Avatar
The seats were redone from scratch using the original fabrics acquired from SMS fabrics in Oregon. There are no re-popped seat covers available...now that I think of it, there is nothing re-pop for these cars.
Old 08-11-2006, 12:50 PM
R 70 Judge's Avatar
Nice work on the trans tunnel!
Do you have any pictures of where the front ladder bar mount is welded in? I'm curious as to how high up in the body you were able to install it. I'm also curious to see where it ended up with your 33 1/2" ladder bars since I will be using 32" Chassis Engineering bars on mine.
Do you plan on installing a roll bar/cage? I'm going to check on the progress of my '63 at the chassis shop after work today. If my cage is done, I'll post some pics.
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 08-11-2006, 02:37 PM
spartazoo's Avatar
I will put the car up on jack stands this weekend and take some photos of the front ladder bar brackets that I had made and where they sit.
I do not plan on a cage right away. If the car is fast enough where it can't run without one I will have one installed. I dont think that it will be. I want this car to be setup as they were back in the day.
So we will see.
Old 08-17-2006, 11:19 PM
4spdT37 4spdT37 is offline
Default cool!!!
Lookin' good Kip!
Keep up the good work. You'll get there, it just takes a little more time than what you plan, especially with little one's.
Past Poncho's.....
1958 Pontiac Chieftain/ old stock class drag car
71 T-37 400 4spd Nordic Silver
71 GTO 455HO Nordic Silver
71 GTO 400 4SPD Tropical Lime
70 GTO Convert 400 4spd 3.90 rear
70 LeMans Sport 400
69 Firebird 350HO Carousel Red
Tom Miller
"Just because it hasn't been done, doesn't mean that it can't be done!!!"
Old 12-19-2006, 04:19 PM
spartazoo's Avatar
I am finally getting back at it...
The new trunk floor for a sumped fuel cell is going in.
Old 12-19-2006, 04:20 PM
spartazoo's Avatar
The rear disc brakes are fitted to the car and clear the plain steels!
Old 12-19-2006, 04:23 PM
spartazoo's Avatar
The bottom of the car is detailed and the interior floor is done. The car goes next week to the chassis shop for drive shaft, pinion angle, and weld check.
Since these pictures were taken, the body has been blasted and etch primed. I will have pictures of that soon.
New goal is to be at Goodguys in Indy in June.
ID:	76335   Click image for larger version
ID:	76336   Click image for larger version
Old 12-19-2006, 04:26 PM
spartazoo's Avatar
Oh...I will take pictures of the front ladder bar mounts when the car gets back from the chassis shop.
Old 12-19-2006, 10:00 PM
Thumbs up nice!
Lookin' Great Kip! Keep at it.
Let me know when it's going to be back home so I can swing by and check it out in person.
Past Poncho's.....
70 LeMans Sport 400
Tom Miller
Old 12-21-2006, 08:14 PM
afx421's Avatar
afx421 afx421 is offline
awesome car! looking great! if i ever find out how to send thumbnails of my sd replica id gladly post them, it keeps saying my file of 1.03 mb is too big for the 300 kb or somethin like that
Old 12-21-2006, 08:33 PM
spartazoo's Avatar
email them to youngc70@hotmail.com and i will resize them for you.
  #38
Old 12-22-2006, 06:14 AM
Brian Baker's Avatar
Where's the panhard bar on that rear? I'm looking for it but I can't find it. Without it, you're going to have problems with it walking "port to starboard" in the car when using just the ladder bars to locate the rear.
What a douche the Stockton wheel guy was, changing your custom order like that without telling you.
  #39
Old 12-22-2006, 08:46 AM
spartazoo's Avatar
Post #33 center picture right hand side of the center section. You can see the bracket for the panhard bar...believe me, it's there.
  #40
Old 12-22-2006, 04:02 PM
bikerdaveandjenn bikerdaveandjenn is offline
i am in the process with a '63 also. i want to run a 28x10 or maybe a 29x10. your project looks great! i cant wait til im THAT far. nice fab work!!
thanx Dave
